Another AWD delete thread
Old 03-27-2022, 10:30 PM
  #46
997Troy
997Troy's Avatar
Originally Posted by skaper
agree. After a few drives it’s hard to identify. I had a buddy, who owns a .1 4s, drive my car and he couldn’t hear the whine.
If you do any more research on it, keep me posted. At this point, I am not worried about it. If it’s something that can be addressed when I do an LSD or potentially flywheel, I may consider.
Are you guys doing these on .1 or .2 c4's??
Old 03-28-2022, 02:29 PM
  #47
andino
andino's Avatar
.1 c4s. .2s have a similar electronic awd system to the 997 turbos.
Old 03-28-2022, 03:49 PM
  #48
997Troy
997Troy's Avatar
I was told you can’t disable the awd system and drive at the limit with the .2’s. However, some spirited driving is fine, just not a track going car
Old 04-19-2023, 01:45 PM
  #49
9971tt
5th Gear
9971tt's Avatar
Default Rwd weight reduction
I didn't have a way to capture the grease from the 50 or so rags or remove it from my pants that were ruined so I'd figure another pound for the grease everywhere and a few misc bolts that didn't make the scales bit with the scales reading 67 lbs I feel it's safe to say the delete is a 68 pound reduction. (Performed by re using the axle stubs from the cv).
The following 2 users liked this post by 9971tt:
997Troy (04-19-2023), bpat (04-19-2023)
Old 04-19-2023, 04:49 PM
  #50
997Troy
997Troy's Avatar
So in other words it’s free? No other parts needed?
997.one (04-21-2023)
Old 04-20-2023, 11:39 AM
  #51
9971tt
5th Gear
9971tt's Avatar
Yes. On my 07 with tiptronic anyway the conversion required no additional parts. I did find a leak on a coolan line that ill fix next time its on the lift (part will be here today) and still neet to order more screws for the rear bottom aero or skid cover (whatever it's called) as I was a few short from re installing it.
Can feel the power increase. I think I'll balance the front tires and get an allignment to see if it helps the loose feeling front end it does pull to the left a little now and seems a little dirty. It may require swapping some suspension components or lowering the front a little to compensate for the lost weight. Part of it is likely just that the front is so much more free to move now. Power drifting seems ok on corners, ill have to take a trip up the mountain and see how she does now on long tight corners.
Quick Reply: Another AWD delete thread
