Easy update to MagSafe for Rennline Phone Mount
I put a Rennline Exact Fit magnetic phone mount in my 997.2 a few years ago right after buying the car. It worked great. Stick the steel plate on the Iphone X case and it stayed put all this time.
Recently got a new iPhone 13, and the 13's Mag-Safe case for use with the wireless charger wasn't compatible.
Wandered around BestBuy and found this Otterbox MagSafe Vent Clip Mount. Easy-peezy, just unscrewed the ring and it fits perfect on the ball-stud of the Rennline mount. It's just a mount, not a charger, but it holds the new MagSafe iPhone 13 case securely and perfectly.
Motorculture (01-13-2023)
FYI, the Spiegel MagSafe Car Charger fits on the Rennline mount as well.
If you buy it, buy direct from Spiegel because they are currently selling a Gen 2 that has magnets that are 3x stronger than Gen 1.
It’s low profile and the phone is on super secure.
8KaboveMSL (11-24-2021)
Good to know about the chargers. I'm ok with the wire for now.
I like the "oval" one, because the new mag-safe phone case has a vertical strip, right below the circle. That keeps it locked in straight up and down so it doesn't go spinning around on the magnet.
Good to see there are several off-the-shelf solutions.
The magnets are strong enough it holds in place with no spinning or deflection.
Even when chucking my car around tight turns on Lime Creek Road.
I also have a clear case like yours.
Yep, just need to disassemble and put the post from the Spiegel on the Rennline base.
My phone doesn’t spin, ever.
ATX_Native (12-02-2021)
I found that Apple's 'basic' magsafe charger will stick to the magnetic piece that comes with the Rennline mount and works pretty well as it allows you to move the phone outward slightly, which helps keep the Max-series iPhones from getting in the way when you shift into 5th.
I love the Rennline mount, but do wish it put the phone about 2" higher.
BerlinDaniel (11-23-2022)
I keep my car on a tender that's connected straight to the battery when it's in the garage, so am less concerned about parasitic drain than many may be.
