Engine oil viscosity
Old Oct 19, 2021 | 05:13 PM
  #31
ai2pz's Avatar
ai2pz
Originally Posted by Bruce In Philly
2009 C2S 175K
I don't see a reason to not like Ceratec for settling. The amount of suction and flow of oil through these engines is amazing... huge flow. Anything like that will get sucked up and mixed almost instantly. IMO.
I can't find anything definitive on our oil pumps, but assume 1 quart per second of flow.... roughly. That is what you call circulation.
Peace
Bruce in Philly (now Atlanta)
Keep in mind that ceratec in oil pan will be thinn layer at bottom when calm down,maybe 1mm height,because oil pan is relatively wide and percentage of ceratec relatively low and oil pump inlet is always few cm up from oil pan bottom.
also before use ceratec you must shake can very well, because all boron nitride (white powder) stay at bottom..
Old Oct 19, 2021 | 05:27 PM
  #32
Dk27's Avatar
Dk27
Solubility isn't an important attribute for the additives to do what they were intended to. With the engine running, the additive will be distributed throughout, providing boundary layer lubrication.. This is why for moly a little goes a long way and more is just a waste of money. You don't need an A40 approved oil unless you have a warranty that requires it, or it makes you sleep better at night. Driven oil based on oil analysis number looks great. The UOAs are intended to track wear metals, and don't necessarily tell the full story behind the oil's additive packages, as there's quite a variety for the chemists to choose from. The m96/m97 engine tends to suck aerated oil on long sweeping right turns under acceleration so folks have done what they can to combat this. Deep sumps with additional baffling and windage trays to keep oil near the pickup, better cooling with the LTT and 3rd rad to help keep the oil cool and maintain viscosity, There is a lot to learn on these forums by reading the numerous threads on all these topics that have been discussed. Do keep reading, but try to keep the inflammatory threads down. Here are two great threads on the oil pressure topic that should keep you busy:https://rennlist.com/forums/996-foru...ispreloading=1 and https://rennlist.com/forums/996-foru...ds-v2-2-a.html
Old Oct 20, 2021 | 09:12 AM
  #33
Fullyield's Avatar
Fullyield
Originally Posted by silver_tt
The safest strategy is starting with a "good" oil that is already compositionally where you need to be rather than from somewhere else and trying to add Cera Tec or other additives to get there. There are many high quality oils; I personally am a fan of Driven oils based on testing it in a number of different engines and at $10/quart the price is right. A more viscous oil will provide better protection but you also want an oil that doesn't shear out of grade before your OCI (oil can shear either temporarily or permanently).
For any engine I own I always look at the approved oils list just to see what the approved viscosities are (not brands). Then I choose the highest viscosity oil you can run choosing an additive package based on if the engine is turbocharged direct injected. The Driven oils get you were you need to be in either direction (and I'm sure there are others as well but I don't have experience testing them to know which ones).
Please share where we can buy Driven oils at $10 a quart. Best price I can find this morning is on buying a case (12 qts.) is $151 or over $12-13 @ qt. at LN Engineering (recommended), Summit, Stoddard, Amazon, etc. Thanks for your assistance in advance.
Old Oct 20, 2021 | 09:47 AM
  #34
silver_tt's Avatar
silver_tt
Advance Auto Parts sells 10 packs of Driven DI40, for example, for $139.99 and you are able to use discount codes, which are very easy to find online (if you load the website in incognito and click around it will start offering you discount codes). It also comes with a Wix XP filter which I have no use for so I just give it to my indy because he's a great guy.
Old Oct 20, 2021 | 10:56 AM
  #35
Fahrer's Avatar
Fahrer
Dispersion.....not solubility. And, it is important for insoluble additives to be properly dispersed to do their job. This may not be an issue when the engine has been running but I am not so sure about startup.
Old Oct 20, 2021 | 11:19 AM
  #36
silver_tt's Avatar
silver_tt
2009 C2S 175K
Peace
I believe your engine is running about 15" H20 vacuum. For a modern engine this really isn't that high. Eg. My Audi 2.0T runs a vacuum spec over twice this (~35" H20).
Old Oct 20, 2021 | 12:35 PM
  #37
ai2pz's Avatar
ai2pz
I think when I contact LM with email ,they said me that ceratec ceramic with high temperature and pressure make thin layer that will stay attached at surfaces for 50 000km,So even in next oil change you dont put ceratec this thin layer will stay on surfeces and reduce metal to metal contact.long term effect. so in that sense settling is not problem..
Old Oct 20, 2021 | 12:48 PM
  #38
Charles Navarro's Avatar
Charles Navarro
Platinum Sponsor
Unfortunately there aren't any magic molecules that will bond to the surfaces and last once the oil containing that additive is drained out. In normal operation, the detergents in the oil will strip the anti-wear film from those surfaces which are then re-applied by the additives in the oil. One reason race oils work so well is that they usually have little or no detergent in them to get in the way of forming these tribofilms.
Old Oct 20, 2021 | 12:53 PM
  #39
Fahrer's Avatar
Fahrer
Which is why they are not suitable for normal/typical driving environments.
Old Oct 20, 2021 | 12:57 PM
  #40
ai2pz's Avatar
ai2pz
I agree with you.Probably more marketing talk.
at additional information
https://products.liqui-moly.com/cera...imo_b2b_com_en
Old Oct 21, 2021 | 12:23 PM
  #41
silver_tt's Avatar
silver_tt
Been giving this more thought. To clarify, crankcase vacuum and oil pressure are obviously not the same thing -- so in some sense my comment above is not entirely relevant. Actually if I'm thinking about it correctly, higher crankcase vacuum (negative pressure) should correlate with lower oil pressure (positive pressure) all else equal.
Old Oct 21, 2021 | 01:33 PM
  #42
Papamurphdog's Avatar
Papamurphdog
Switched to Driven oils early this season. Running their XP9 10w40 for track weekends. Running their DI40 0w40 for street and cold weather track time (base oils are the same generally). I am running the LN deep sump motor oil pan and their deep sump PDK pan. Also have the CFS side rads and added center rad. My car is a 3.6L NA with a Softronic flash. I dump and refresh motor oil after 6 track days, max (usually after 4 event days). I dump and refresh DCT on the hydraulic side of the PDK after 8 event days, max. Gear side was mid-season. I'll do that again after my last event this season, then again at mid-season. Fresh fluids are WAY cheaper than replacing hard parts. :-)
Old Oct 21, 2021 | 01:41 PM
  #43
Papamurphdog
Quick comment: in my 3.6L NA motor, the oil passages and tolerances are really tight, so, it really likes the 0w40, over the 10w40, and it really hates the 15w50. The latter being too think -- raised the oil temps by about 15 degrees on the track. Immediately dumped it and went 10w40 and temps dropped sharply. 5 degrees cooler still with the DI40 (and for sure less soot). Just an FYI on what i observed this season so far, after 20 event days.
Old Oct 21, 2021 | 02:27 PM
  #44
silver_tt's Avatar
silver_tt
I always appreciate data points and like to hear others' observations. I agree with you and should elaborate that when I choose the highest viscosity oil I mean I use that as a starting point. There is no one size fits all and the only way that I know of to figure out which oils are best in a given engine is to try them and see (including UOA). In my engine I have experimented with several multigrade viscosities and brands. I have found it likes Driven DI40, a 0W-40, the best but what's interesting is that it seems to like it more and more each oil change. Immediately after switching I saw an uptick in oil consumption but it gradually waned after several OCIs and it has been reduced to zero while my wear levels have been reduced to nothing. Protection of soot formation is the biggest benefit of running this oil in my opinion; soot is the single biggest drawback of GDI technology IMHO. Oil comes out of my engine looking very dark. Some of that has to do with the fact that some oils just naturally turn a darker color over the course of an OCI....however with GDI engines I have observed the oil to be especially dark and I attribute this to soot formation.
Old Oct 21, 2021 | 04:15 PM
  #45
ai2pz's Avatar
ai2pz
But lower oil temperature dosent strictly mean that this oil is better then hotter one.if you put 0w20 temperature will be even lower,but oil film will be too thin and it can brake.
Do you agree?
