Battery current draw passenger seat
2005 997.1 battery is healthy. Current draw related to something connected to passenger seat. Drains the battery within a week. I have a standard seat, no memory settings. Two adjustment buttons only. When Fuse is pulled for the passenger seat there is no excess draw. Thoughts are a tracker perhaps? Before we go pulling up carpets, just wondering if anyone has had similar issues? Thank you!!
I gave this information in another post: "Battery drain Help"
Some 997 cars had this issue with a bad NAV module, this module is located under passenger seat.
In case of permanent current consumption, it's always hot.
I don't know if this module is connected on the passenger seat fuse ...
Thank you! Im going to look into this
You may want to test pulling the fuse and checking the draw.
**Beware when you pull the fuse it disconnects the Airbag deployment function.
