IMS bearing 997.1
Old 06-25-2021, 03:16 AM
sandwedge
sandwedge's Avatar
Received 1,041 Likes on 736 Posts
Originally Posted by 3rdpedal
Not all 06 models have the larger bearing. You should be able to check the engine number under the car without taking anything off. I don't have the details but less than XX is servicable and over XX is not. That will tell you if you have to worry.
Are you sure? The consensus here and elsewhere seems to be that even mid-year or later -05 cars got the larger bearing and definitely all -06's. Never heard of an -06 with the small serviceable IMS.
Old 06-25-2021, 09:08 AM
4Driver4
4Driver4's Avatar
Agreed. Unless the engine was swapped, anything late 05 and later is big bearing.
Old 06-25-2021, 09:17 AM
Petza914
Petza914's Avatar
Received 6,594 Likes on 4,192 Posts
All 06s have the larger bearing.
Quick Reply: IMS bearing 997.1
