Engine electrical connectors
Old May 9, 2021 | 03:16 PM
mklep029's Avatar
mklep029
2nd Gear
Default Engine electrical connectors
Mice chewed multiple sensor wire on 997 (2008 C4) I have dropped the engine which was a chore to say the least. I am looking for a source for the male parts of multiple electrical connectors. The mice chewed the wires off flush with the male plug. One option would be to disassemble the connector and insert new pins/wires and another would be new connectors. Even used parts with intact wiring could work. The connectors have numbers in them and will try to search them out. Anyone know how these parts can be acquired ?
Old May 9, 2021 | 04:42 PM
PapaC4S's Avatar
PapaC4S
Lot's of sources for electrical connectors and pins. Try Digikey or Mouser. Most modern connectors are easy to disassemble and pull the pin. Just need a set of connector depin keys. Can get them cheap on Amazon. See this post. https://rennlist.com/forums/997-foru...bber-boot.html
Old May 10, 2021 | 01:48 PM
Petza914's Avatar
Petza914
www.findpigtails.com
www.connectorexperts.com
