30mm spacer for nb wheel on wb?
I guess my next question is, does running a 7 front and 15 rear on an nb wheel setup vs 7 front and 15 rear on a wb setup mess with suspension geometry? It seems as if the fronts stick out wider than the rears.
I run a 25mm spacer on my rear to bring the 997.1 GT3 wheels flush with my WB.
But like Petza mentioned it is an adaptor style so that I just use regular length bolts.
No issues at all.
I wouldn't hesitate to recommend them.
But in full disclosure I remove them when I go to the track as my track setup is designed for wide body....
No issues at all.
dont forget that the oem sport wheels (same for both 997.1 + 997.2) only came in NB fitment.
if u get them of the c4s WB, porsche throws on an oem 20mm-ish spacer for that one specific wheel. i believe it was 11.5 +67mm rear
i believe they were 8.5/11.5 inch wheels - cant remember the offsets but if you dig hard enough you will find these specs, as well as the WB 30mm oem rear spacers used.
Rulaxin12 (05-01-2021)
