"Notchy" When cold (gearbox)?
Old 04-17-2021, 11:27 AM
larrygk
larrygk's Avatar
Originally Posted by texass4
Don’t go wasting money on a bunch of aftermarket stuff. This is just one of the reminders your car uses to keep you in check until all systems are go. This and the oil temp gauge.
Joking aside, I consider it a feature, not a flaw.
You're right. Back with my '06 Cayman S I learned that nothing went over 3k until H2O temp got to normal. I will take this opportunity to replace the cables though. Even when warm I don't like the overall feel. Had not heard of the Shift Right brand. Only about 50 bucks less than the Numeric. Anyway, PTX (gold $ in a bottle apparently) ordered.
Old 04-17-2021, 11:47 AM
Prairiedawg
Prairiedawg's Avatar
Received 1,021 Likes on 546 Posts
You want your oil at normal operating temp before you flog it, not water. Water gets there way before oil.
Old 04-17-2021, 12:20 PM
larrygk
larrygk's Avatar
Understand that...small detail..no oil temp gauge in a 987.1 Cayman S.....So H2O temp plus 5 minutes did it.
Now I'm good with "real" gauges on the 997.
Old 04-18-2021, 03:40 AM
jibmaster1
jibmaster1's Avatar
I bought my 09' C4S last September. The shifting was really poor. I went through and re-greased the shifter and installed FF cable ends. These made small steps in improving the feel and reducing the notchiness. However, after I looked through the stack of receipts I had from the PO, I noticed the shop that changed the trans fluid used Redline a few years ago. I've had no issues with RL in some early manual Audi's and VW's I owned. However, the best improvement happened a few months after I switched over to the factory PTX Porsche Fluid. The shifting progressively improved after putting about 1000 miles on the car. Now, I actually think it is really good!
larrygk (04-18-2021)
Old 04-18-2021, 11:18 AM
larrygk
larrygk's Avatar
Thanks,,,I ordered the PTX, No receipt from PO on that aspect so hopefully what was used was not PTX in the past. Wish I had a lift. I can do oil with the JackPoint Jackstands I've got but not this for a couple of reasons. So off to the Indy and will discuss either FF's or Numerics (about a $50 difference it appears).
Old 04-18-2021, 11:22 AM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,567 Likes on 941 Posts
2009 C2S 171K miles
Back when I did my PTX research, I found the two Porsche dealers near me used Delvac. They were totally unaware that spec'd right in our manuals was a different formulation oil.... PTX GL 4.5 is written right there. I assume it is noted in their procedure manuals too, although I am not sure of that. So... even if a dealer serviced the car does not mean they did the correct thing.
Peace
Bruce in Philly
Old 04-18-2021, 11:23 AM
Ericson38
Ericson38's Avatar
PTX and thorough clutch bleed did it for me, using stock cables. About 40% improvement from each. Clutch bleed ensures that between shifts, the clutch is completely disengaged, so that the cogs are not loaded up with residual torque transfer loads.
2006 C4 Cab-69K miles
Old 04-19-2021, 07:32 PM
wndsnd
wndsnd's Avatar
The transmission needs to warm up its fluid.. Remember it is something like 90 weight.. I think the recommendation by Prairiedawg is good advice. Though unrelated, it gives a good measurement of time.
I also noticed that when I let a friend try my car last week (I know, I know) ,He was shifting like an American car and just trying to slam the box, It took me a while to get him to slow the shift down, and feel it into gear.
Old 09-06-2023, 04:04 PM
RZau
RZau's Avatar
Default PTX
Is the PTX oil worth it as my 2010 911 has this same issue? Hard getting into gear w/o a feel of spinning teeth once and a while and the notchiness all the time when cold. Once warmed up everything is like butter. Thanks in advance for any input.
Rob
tegraphile (09-08-2023)
Old 09-08-2023, 12:27 PM
tegraphile
tegraphile's Avatar
Improved my initial notchiness with:
--Function First shift right kit
--PTX trans fluid replacement
--Function First engine mounts
Old 09-08-2023, 05:44 PM
tegraphile
tegraphile's Avatar
Rob
It's a simple enough change (drain and fill, accessible from the underside) with the potential to make a big difference. I think it's worth it.
Old 09-08-2023, 05:50 PM
Bruce In Philly
2009 C2S 192K miles
I changed my motor mounts at about 100K miles as one was sagging a bit... did not effect shifting one bit and I had a jammed 1st gear for years before and after. Amazing how our experiences can differ. Same for my installation of the Numeric shifter... no difference in shifting (just a way better feel)... although I did not use the alignment tool, I just eyeballed it... but as I noted above, I can't see for the life of me how shifter position can affect anything.
Peace
Bruce in Philly (now Atlanta)
Quick Reply: "Notchy" When cold (gearbox)?
