Plenum boot Seal with IPD
Old Mar 3, 2021 | 05:51 PM
wndsnd's Avatar
wndsnd
Default Plenum boot Seal with IPD
Anyone have trouble getting a good seal between intakes and the IPD Plenum. Would it be a real no no to maybe add some silicone sealant around the plenum intakes and then reseat the seals. I assume it is on the plenum side as the stock intake and seals never had a problem with stock clamps.
John
Old Mar 4, 2021 | 01:04 AM
OKB's Avatar
OKB
whats the problem
Old Mar 4, 2021 | 06:13 PM
wndsnd's Avatar
wndsnd
Originally Posted by OKB
whats the problem
Suspected vacuum leaks, bucking stalling, misfires. I have the boots secure, but now I am thinking of further sealing. I have decided to use 2" linerless rubber self adhesive tape on the mating surfaces to see if that clears anything. If that does not work I have at least eliminated one possibility..
Old Mar 4, 2021 | 07:28 PM
workhurts's Avatar
workhurts
On an S or base? Isn’t there an additional connection for an S? Anyway, be sure to trace all around to make sure everything is actually mated up. When I did mine, I thought I had it on but it wasn’t completely sealed. That thing is on so tight, I can’t imagine a leak.
Old Mar 4, 2021 | 09:10 PM
rtl5009's Avatar
rtl5009
I have not had a problem. Have you smoke tested it?
Old Mar 4, 2021 | 09:57 PM
OKB's Avatar
OKB
yea, reverse smoke test, spray carb cleaner around gasket and see if it surges the idle
Old Mar 5, 2021 | 10:33 AM
wndsnd's Avatar
wndsnd
I took it all apart again last night and redid the boots. Still a problem. I have a MAF sensor coming today to see if that works, I cleaned mine but that did nothing. I would like to try the brake fluid trick, though I would probably use starting fluid, but car will not idle. It dies.
Old Mar 5, 2021 | 10:37 AM
wndsnd's Avatar
wndsnd
I hate just replacing parts. The only code I got was for the precat ox sensor, so I did replace that and that cleared. Right now I am only getting misfire codes on all cylinders left and right banks. That makes me think I still have a vacuum leak. I am doing the MAF, but I get no codes for it. If that works I will be surprised
Old Mar 5, 2021 | 12:51 PM
wndsnd's Avatar
wndsnd
I played with the Plenum boots and got a reseal. That cleared up my rough running and it is now not throwing codes.
Vacuum leaks are the devil 😈
Old Mar 5, 2021 | 03:01 PM
hatchetf15's Avatar
hatchetf15
^^^^ Too freaking true!
