Oil additive question-Ceratec?
#61
Wow this turned into an oil thread, didn't mean for that to happen, but it's ok as it is ultimately related.
So, as far as DT40 goes, how long / many miles before it affects your catalytic converter, if at all. IIRC that is the reason why it was not an approved oil according to one of the earlier posts.
To clarify, DT40 isn't Porsche approved as they do not use an approved A40 additive package. Regardless of brand of oil, all A40 oils are formulated the same with similar levels of ZDDP and other additives as they are required to use the same recipe to carry that approval.
Remember, there are only a handful of base stock and additive suppliers worldwide.
Fullyield (01-28-2021)
#62
Here is a RL Oil Analysis Spreadsheet previously prepared and posted by others in our great community (thank you!). It has comparison of Blackstone UAO for 13 samples of Mobil, Motul, LM and Driven....including some with MOS2. As there was no data for M1 5W-50 or Ceratec, I added my Blackstone UOA results in last column for comparison. That LM HT 5W-40 looks pretty good in this comparison, but, like Driven, it is not A40 approved.
#63
Thanks for that. Looks like Motul is not that great by itself, wonder why it is so touted? Wear numbers look similar to mine, that's why I will be adding Ceratec for now until my next oil change at which point I will most likely switch out to DT-40 or maybe LM with added MoS2 being that I just received two bottles.
#64
Just add some MoS2 or some Ceratec to it. Great stuff.
https://d23zpyj32c5wn3.cloudfront.ne...pdf?1492016165
#65
Here is another two data points. Both of the samples seen in the photo are Motul 5w-40 with one bottle of MOS2 at the oil change. I will post more when I am not on my phone. I am wondering how much MOS2 has really helped.
#67
What matters are wear metals, viscosity, and acidity of the oil. You didn't run a TAN and TBN on this samples so we don't have those numbers, but viscosity is low and wear metals are kind of high. Personally, I'd use something else based on what I see here.
#68
#70
Hi. I'm Ken and I'm an oil fanatic. After a lot of research years ago I started using Motul 5-40 in my 997.2, and more recently adding MOS2 at each change. I don't understand a lot of the information from the oil analysis I see here, but I also don't see anything to convince me that any of the oils, or additives, are consistently better than others. Also, with about 5 decades of driving behind me, I remember only one person losing an engine to an oil related problem and that was sludge in a Camry. I'm beginning to think that unless I spend time tracking my car I can just buy a decent oil of the proper weight and it will make zero difference to my motor. If there is any oil that consistently has the best UOA's please tell me what it is and I'll become an instant fanboy. I'm beginning to regret the hours I've spent reading oil threads that take me on a circuitious route to nowhere.
#71
#72
NF4710 (08-01-2023)
#74
As I've stated previously, all A40 oils are going to perform very similarly because they all have to use the same pre-approved A40 package in an approved base stock. The only variable is the viscosity and the only distinguishing factor between these oils will be the HTHS viscosity. The higher the HTHS viscosity the lower the fuel economy. That's why we have always told customers if they wanted to run an A40 oil, that they should use a 5w40 over a 0w40. A 5w50 would have even higher HTHS viscosity, however having such a large spread means they have to use more viscosity modifiers that tend to break down, meaning these oils will shear out of grade faster than a 5w40.
For example, M1 0w40 has historically been formulated at the bottom of the tolerance for a 0w40, no you're not going to beat it when it comes to fuel economy. To give you an idea how large a range there is, for a 40 weight the kinematic viscosity can be 12.5 - 16.2 mm²/s.
I know Petza914 does regular used oil analysis and has shared his UOAs running Driven oils in his vehicles here on Rennlist.
#75
For those looking for VOAs for popular oils among Porsche users, check out SPEEDiagnostix website. They have a bunch posted there:
https://www.speediagnostix.com/new-oil-analysis-results
