Going to be doing a brake job on my '06 2S and was wondering what folks are using for street application only. Since I live in the mountains I do plenty of spirited runs up and down so that probably needs to be taken into consideration as well. I plan to replace the rotors as well as the pads and would like to get some pads that don't dust too much. It seems there are a lot of options available and I'd like to hear about what's working for others.
Yes. Been up here over 25 years. I'm the head brewer and one of the owners of Idyllwild Brewpub.
Cheers,
Don
Right on!! I'm down in San Diego and actually going to be passing by your neck of woods, Indio-Winchester-Hemet-Beaumont-10 this Friday and going to Chuckwalla.
You should go through Anza and then down to the desert on 74. Much nicer drive. 79 our of SD, through Julian, to 371 (Anza), to 74 (at Paradise Corner), to 10.
The Ferodo DS2500 would be an excellent choice for your situation. They have far better feel than stock pads, but the big deal in your case would be their maximum operating temperature. They are perfect for canyon carving, and some people even use them for light duty track use. We also offer 2-piece AP Racing discs for your car as well, if you decide you want something a bit more durable and lightweight vs. stock. Our discs are probably overkill if you don't plan to do any track driving however.
We are a long-time Rennlist sponsor, and appreciate your support. Thanks!
Thanks in advance.
Cheers,
Don
'09 Carrera 2S, '08 Boxster LE (orange), '91 Acura NSX, Tesla Model 3 Performance, Fiesta ST
Jeff Ritter
Mgr. High Performance Division, Essex Parts Services Essex Designed AP Racing Radi-CAL Competition Brake Kits & 2-piece J Hook Discs Ferodo Racing Brake Pads Spiegler Stainless Steel Brake Lines
704-824-6030 jeff.ritter@essexparts.com
dba rotors (2 piece in the front and 1 piece in the rear) and Hawk Ceramic pads. Run this combo on my wife's 05 997 C2S. Then at the next brake job you can buy replacement front rotor rings and reuse the lightweight aluminum hats instead of having to buy new rotors. Part numbers for the rear are complete rotors. Part numbers for the fronts are just the rotor rings. Brake pad #s are for front and rear Ceramics.
I've done that before and it goes through a nice mountain pass down to Rancho Mirage. Unfortunately, I'm taking my truck with the moto in the back so switchbacks won't be as fun.
