Groaning sound
Groaning sound
Good afternoon,
I purchased my first Porsche, a C4S, a month ago, and while I love the car, I'm trying to identify a persistent noise.
I'm hoping for some help in eliminating a groaning / low squeal sound. It sounds like a low pitched brake squeal, but, unlike a brake squeal, the sound is short in duration. It doesn't seem to be a rotational sound like you would expect from brakes. The sound occurs at low speeds, generally while turning left, but has also begun to make the sound occasionally when turning right. Additionally, it will make the noise when going over harsh bumps at low speeds (like every freaking time I pull into or out of my garage!) and under light braking.
Initially I thought the sound may be a warped rotor, and because the brakes were due to be replaced, I went ahead and replaced all 4 rotors and pads. That, of course, didn't make any change to the sound. Since then, I've tried spraying all the bushing with lube to see if I could identify a culprit.
It's really difficult to even determine if the sound is coming from the front or rear, left or right, as the sound seems to resonate throughout the entire car. It does seem to be more prevalent since the weather has turned colder.
It is difficult, if not impossible, to hear the groan from outside the car.
If you have any input on areas I should target, I'd love some direction.
Thanks in advance!
Jon
Thanks in advance!
Jon
Check out Bruce's post on using wireless chassis ears. I had no idea such a thing existed, I stumbled on his post, I bought a set off Amazon, and used them to very easily diagnose an annoying clunking sound in my brand new suspension (was a bad monoball upper strut mount). They are like $200 but worth it because you will have them for life and can save a lot of money and time not replacing things that don't need to be replaced. My guess is that it is a suspension bushing somewhere... could be sway bar bushings, or any of the round rubber bushings.
https://rennlist.com/forums/997-foru...ed-advice.html
These are the ones I bought:
VT Blue (12-03-2020)
I have the same groaning sound. Feels like it’s coming from the steering rack/front suspension. It gets louder as the car warms up and during parked turning of the wheel to both sides. My understanding is that it could be the top hats/bushings of the front suspension.
In my case, my front struts and strut bearings have been replaced recently. Mine doesn't make the noise by simply turning the steering wheel the way a strut bushing would. If I were to guess, the sound in mine sounds more like it's from the rear.
Wheel bearing maybe?
I wondered about a wheel bearing, but I don't feel any play in the wheel when I try to rock the wheel when it's on stands. Additionally, I don't the typical groan sounds of a bearing at speed.
Received 1,919 Likes
2009 C2S 164K miles
If it is the strut bearings on the top, you can easily fix that..... a short-term fix is to squirt a ton of silicon lubricant up there.. spin the wheel left-right etc. Better is to shoot some Winzer Polylube up there. Read about it here: https://rennlist.com/forums/997-foru...ube-it-up.html
Peace
Bruce in Philly
Peace
Bruce in Philly
2009 C2S 164K miles
Peace
Bruce in Philly
Peace
Bruce in Philly
Winzer Polylube is like the best stuff on the planet.... penetrates, dissolves, goes in as a liquid, then sets up as a sticky high-temp grease.
Peace
Bruce in Philly
If it has just started doing it now that the weather has cooled off where you live, it's likely the sway bar bushings. Take apart and regrease or replace them while you're in there. Rears are easy, fronts a little less so because of what has to be removed and loosened to get to them.
If it has just started doing it now that the weather has cooled off where you live, it's likely the sway bar bushings. Take apart and re grease or replace them while you're in there. Rears are easy, fronts a little less so because of what has to be removed and loosened to get to them.
Peace
Bruce in Philly
