911 997 Front and Rear Pads and Rotors change with 350mm upgrade DIY
Hey fellow 997 owners, I recently changed out my 997.1’s pads and rotors and wanted to share with you’ll, the DIY. In addition, I performed the “poor man’s BBK” to the “S”. This involved upgrading the 330mm rotor to the 997 Turbo’s 350mm by using small “brackets”.
It’s not a difficult job to do at all. As long as you have basic tools, a caliper retractor, as well as torque wrenches, you’ll be good to go!
Feel free to post up if you have any questions or feedback on how I could have done a better/easier job. Sub to my channel is you haven’t already and thanks for the support!
Perhaps an Admin can post as a sticky in the DIY?
linderpat (12-01-2020)
Hi,
I watched your video but without sound (at work ^^)
Could you tell me where you found the spacers and studs or their specs (lenght... ) because it might be easier to fabricate them.
To you use some special pads or the original one ?
That might be a cheap nice mod to do when the disk are used, for me it is more for a better look than for heat because I think that our small 330mm rotors doesn't look that well in big wheels (I run 19s on my 997.2 base carrera)
I totally love the look of the 718 with big rotors and callipers.
Nice video, thanks for taking the time to go into detail on the installation. I did the upgrade over a year ago and absolutely love it.
There is a rennlist member @Flewis763 who makes them as well. He sells them on ebay.
link below...
Ebay_caliper_bolt_spacer_kit
Here is another forum discussing them.
https://rennlist.com/forums/997-forum/1040067-diy-330mm-to-350mm-rotor-upgrade-install-2.html
link below...
As regards the existing sticky for 997 DIY/Tech articles: https://rennlist.com/forums/997-foru...ech-index.html
You can simply post your video there, doesn’t require an Admin to help.
Karl.
Karl.
