Oil quantity warning message
Old Oct 31, 2020 | 09:29 AM
roccocaiazza's Avatar
roccocaiazza
Default Oil quantity warning message
Just bought a 2009 911S. Driving after 30 minutes the oil quantity message came on. Checked oil and and quantity was full. Book says message may mean over service of oil.
I have all records and oil was serviced by Porsche dealer less than 50 miles ago. Person I bought car from did not drive the car after service as he was selling car. I had a PPI. I wonder if the message did not come on for him since the car did not get to operating temperature until I drove the car. Also according to owner’s manual the oil quantity message and low oil light are 2 separate sensors.
Old Oct 31, 2020 | 11:49 AM
Ironman88's Avatar
Ironman88
What is the exact warning message the you are seeing?
Is the segment indicator flashing (uppermost segment flashing)?
Old Oct 31, 2020 | 12:12 PM
OKB's Avatar
OKB
Probibly not right amount in engine, because it was just changed. i would take it back to that dealer
Old Oct 31, 2020 | 12:14 PM
doclouie's Avatar
doclouie
Check to make sure they reset the service time/mileage indicator.
Old Oct 31, 2020 | 01:41 PM
roccocaiazza
No flashing
Old Oct 31, 2020 | 01:42 PM
roccocaiazza
They did
Old Oct 31, 2020 | 01:43 PM
roccocaiazza
Dealer is 3000 miles from me. I shipped car
Old Oct 31, 2020 | 01:56 PM
Wayne Smith's Avatar
Wayne Smith
Over full can cause a message. Oil expands with heat ... More than you might expect. So what's OK cold may change when warm.
The 9A1 motor is difficult to remove a small amount of oil from. I would recommend draining, measuring, and refilling with a quart less. Then add a bit at a time (over the course of a few days if necessary) until you have one or two bars lit on the gauge. IMHO you never want to see the top bar lit.
Old Oct 31, 2020 | 02:12 PM
Bxstr's Avatar
Bxstr
Agree. Middle of the gauge to me is always where I try to keep it. That way I have a bit of room in each direction.
As far as the message, I would need to know exactly what it said.
You could try and remove a bit from the oil filter housing.
Old Oct 31, 2020 | 03:29 PM
roccocaiazza
Default Message out
Started car and ran it for 5 minutes. No oil message. Tried to check oil level but computer said car was not warm enough. Pretty sure that is was slightly over serviced and expansion causes message
Old Oct 31, 2020 | 04:09 PM
OKB's Avatar
OKB
drain out a couple of cups and see how it responds
Any dealer should be able to provide help and its not a bad thing to make friends with dealers
Old Oct 31, 2020 | 04:23 PM
Jaws1's Avatar
Jaws1
Or better yet a good indy, IMO.
Old Nov 1, 2020 | 08:30 AM
Petza914's Avatar
Petza914
Can't really do this on a .2 like you can on a .1 because the filter housing is inverted and all the oil drains back out.
Wayne's suggestion is the best. Go get a new perfectly clean bucket from Harbor Freight or Home Depot. Drain all the oil into the bucket, then refill with a quart less. Adjust as necessary.
Overfull in either generation car can damage the AOS and foul the spark plugs.
Old Nov 1, 2020 | 11:15 AM
OKB's Avatar
OKB
oil drain plug
Old Nov 1, 2020 | 12:58 PM
Bruce In Philly's Avatar
Bruce In Philly
2009 C2S 162K miles
I never got that message so I would take it very seriously.
As OKB noted, drain the oil and refill. Follow the manual and put back what you are supposed to. Then heat it up and remeasure. If you don't have the tools/jugs to remeasure, take 1 to 1.5 quarts out of the bucket, then refill. If you don't know what oil they used, you may want to just fill it with real Porsche-approved oil... Porsche denotes approved oil as A40 and it will be denoted on the oil bottle.
You may be able to drain just one quart by loosening the drain plug until it jiggles, then jiggle it to get some sort of flow... but I suspect by the time you got the plug to jiggle, it will pop out anyways and you will have a flood. You will need a large, low-profile drain pan... and need to jack up the driver's rear to get under there, or hang the car's butt off of an edge.
As others have noted, don't use that indy... he/she was clueless. While servicing this car is not all that complicated, all they have to do is read the manual, I would go to someone who services Porsches... there are plenty out there. Your typical Porsche indy knows we owners are a neurotic mess and will tolerate endless stupid questions and silly demands.
Peace
Bruce in Philly
