Oil quantity warning message
Old Nov 1, 2020 | 01:18 PM
Bxstr's Avatar
Bxstr
Originally Posted by Petza914
Can't really do this on a .2 like you can on a .1 because the filter housing is inverted and all the oil drains back out.
Wayne's suggestion is the best. Go get a new perfectly clean bucket from Harbor Freight or Home Depot. Drain all the oil into the bucket, then refill with a quart less. Adjust as necessary.
Overfull in either generation car can damage the AOS and foul the spark plugs.
I was specifically thinking of a .2, since there should be just enough that does remain in the filter and also in the canister. But there is a chance that it starts to drain back into the engine. This would also require a new filter, so not as economical. I guess you could also open the drain plug a bit, but not sure if the crush washer would seal quite as well.
Wayne's/your suggestion though is probably best as mentioned.
Old Nov 1, 2020 | 01:23 PM
wjk_glynn's Avatar
wjk_glynn
Originally Posted by roccocaiazza
...Also according to owner’s manual the oil quantity message and low oil light are 2 separate sensors.
Hi Rocco,
The 997.2 has two oil level measuring modes described on p154, but they use the same oil level sensor located in the engine pan.
There is a separate oil pressure sensor located near the oil filter. If that goes off, you’ve a very serious issue. But it’s not an oil level measurement per say (p208), unless the root cause was very sudden low oil level due to a very bad/catastrophic leak.
But under normal circumstances, the pan sensor should catch a low oil level way before you’d loose actual oil pressure for that reason.
Karl.
