997 on back roads ?
but reviews on those don't seem to soften the ride at all.
Well, softening the ride is not the objective of suspension modifications. Doing a suspension modification with any and all aftermarket suspension components are only to improve handling and body roll etc. The softest ride would be achieved with basic, stock shocks and springs, that are already worn out.
Any and all aftermarket are going to be stiffer and harder than stock components
Damptronic Coilovers
Once the OEM needs replacing you can upgrade to a Bilstein B16 DampTronic Coilover Kit. It will still retain PASM functionality, still work with the DSC controller, and will offer things like ride height adjustment. There are a few brands and models of aftermarket kits available that are PASM compatible.
If it were my car, I'd ensure it has PPF for the rock chips and dirt that get kicked up, I'd put a DSC controller on it, and I'd leave the stock PASM shocks in place and replace them with OEM units if and when they fail. I would not upgrade the suspension, get coilovers, etc. I agree with the suggestions of moving to 18" wheels and tires, though your tire selection is quite limited in 997 18" sizes, so I'd only do that if you hate the OEM wheels.
Next year I’ll be getting the DSC, clear bra and custom mud flaps. I’ll take the car to the cottage and see how it behaves.
My rims are lobsters and they are not going anywhere unless I can find a 18” aftermarket !
Hindsight2010 (10-22-2020)
Negative still on stock suspension. It seems like the upgrade of choice if you are running a DSC. Lots of threads on them. I'll swap in some B16s when my OEM needs replacing. So many aftermarket upgrades and modifications available for these cars it gets tough to prioritize.
