Installed Sprint Booster v3
Old Sep 3, 2022 | 12:42 AM
PhillyNate's Avatar
PhillyNate
If your car doesn’t have sport chrono/ sport plus this is a very worthy mod.
Old Sep 12, 2022 | 08:28 PM
qikqbn's Avatar
qikqbn
I liked this so much on my Boxster S, that I purchased a 2nd one and added it to my 997.1 Carrera 4S this weekend. I love that I can dial in the throttle response with up to 18 different settings. This also remembers the last setting when car is off. So when you start back up you do not have to hit the sport button. My C4S came stock with Sport Chrono Sport button, but after playing with this on my Boxster I realized there is more to fun to be had by adding it on top of/in conjunction with my Sport Chrono 911. This is like adding Sport +++++++ button. From Mild to Wild throttle response. You can dial in as much as you want. I highly recommend it. Really wakes up the throttle response.
Old Sep 12, 2022 | 08:36 PM
Petza914's Avatar
Petza914
After watching a couple comparison videos of how this actually modifies the throttle inputs, I've changed my mind about it's usefulness. Realizing that it not only augments the throttle inputs, which is meh, the important part is that it electronically moves the plate faster than the OEM parameters will allow it to move even if it was a binary switch from zero throttle to full throttle.
Once I get things sorted back out with my car, I might try one for fun. Being able to snap 475-485 supercharged HP to the rear wheels in the blink of an eye in race mode might be really exciting.
Old Sep 13, 2022 | 07:07 PM
qikqbn's Avatar
qikqbn
For those thinking about it or have one on order. It takes quite the yoga moves to get into the pedal area. I suggest taking the extra 20 seconds to remove the pedal completely, rather than just trying to unplug the clip from the top alone. Undo the one screw that holds the pedal in place. Once that screw is removed you slide the gas pedal UP and out of a slot.. The clip is a strange one. You slide the release clip tab out first. Then gently push down and try to wiggle the connection off. I actually ended up using a small screw driver and manually lifting the release clip from the opposite direction. It was being a little bugger for me. Just try not to break any tabs or snaps, but a little prying will pop it right off. I took some time and ran the little controller in to my ash tray. Removed the little white plastic light cover in the ash tray for the hole for the wire to run through. Removed my stick shift boot and used a wire hanger to run through there along the center console towards the gas pedal. Took 10-15 minutes to run that plus another 5-10 minutes to install the sprint booster on the pedal.
Old Sep 14, 2022 | 05:32 PM
Hootsama's Avatar
Hootsama
I like the idea of electronically moving the plate faster, but don't really care to have mapping changed. Is there a setting for faster flap only?
Old Sep 14, 2022 | 07:58 PM
qikqbn's Avatar
qikqbn
Not quite sure how you can have throttle plate open faster without a mapping adjustment.
There are 2 modes. Sport and Race. Each mode has 9 settings. You can dial in as much as you like. Feels like a very natural progression to me from mild to wild. Sport and race mode are set at 5 out of the box. Race mode is where I find it can get too sensitive in city driving and pulling away from stop lights in a manual stick shift, but works well when blasting in the canyons or on the track. Sport mode at 5 was a nice, noticeable difference, but manageable to get away from the stop lights and not burn your clutch over revving. Everyone has different tastes and this is a nice modification that you can dial in or is easily reversible if for some reason you don't like it.
Old Sep 15, 2022 | 11:47 AM
Hootsama's Avatar
Hootsama
Thank you! That's extremely helpful practical insight.
Old Sep 18, 2022 | 07:44 AM
Kwmeo's Avatar
Kwmeo
I installed a pedal commander on my 997.2 feels much better throughout the gears
Old Sep 19, 2022 | 03:47 PM
nerdnic's Avatar
nerdnic
I installed the v3 SB last week on my 2009 manual. The throttle response in race mode (red) is amazing, but makes it very easy to stall in daily driving scenarios. This might be because I also did the clutch switch delete, and that alone also made the car easier to stall. I settled on sport 9 since the initial pedal feel is soft enough to allow for better control in stop and go traffic, while mid range to WOT is greatly improved over stock.
Old Sep 19, 2022 | 05:24 PM
Petza914's Avatar
Petza914
I thought the clutch switch mod caused an error code on the .2s. Someone had tried it and after a couple days got an error that those of us with .1s never get.
Old Sep 19, 2022 | 05:29 PM
850tgul's Avatar
850tgul
I would guess it's the clutch switch delete. I have found that the SB makes car less likely to stall given it makes the throttle respond quicker.
Old Sep 19, 2022 | 05:37 PM
nerdnic's Avatar
nerdnic
It does cause a dash error but I just toggle it away and carry on.
I'll have to try with it back on, I'm curious now how it would feel. I agree the throttle response is faster, and you'd think that stalling would be harder because of this. The issue is that you know the throttle response is faster, so you give less gas to avoid high rev starts and cause bog/stalls as a result. At least this is what my brain/foot is doing. Maybe I'm just bad at this
Old Sep 19, 2022 | 07:01 PM
qikqbn's Avatar
qikqbn
sorry for the ignorance, but why is it advantages to remove the clutch switch???
Old Sep 19, 2022 | 07:12 PM
Petza914's Avatar
Petza914
You jumper the wires to it, not actually remove it. The car changes the timing as the clutch is releasing. It causes that weird farting exhaust tone that some people hear and kind of disconnects the linear feel of the clutch. It's done so inexperienced manual drivers are less likely to stall the car when leaving a stop.
Old Sep 19, 2022 | 07:17 PM
qikqbn's Avatar
qikqbn
first time hearing about it, didn't know it was a "mod" people did. I thought the switch was just there for starting the car when the clutch pedal is in. thanks for reply
