Undercoating removal
Old Sep 18, 2020 | 01:57 AM
gary1101's Avatar
gary1101
Default Undercoating removal
I am cleaning some of the suspension bits and I am having a hard time removing the waxy factory undercoating. What is the best method for removing this.
Old Sep 18, 2020 | 07:38 AM
rtl5009's Avatar
rtl5009
Fine wire wheel.
I did it on my oil pan-
Old Sep 18, 2020 | 10:46 AM
Petza914's Avatar
Petza914
It's called cosmoline. Red Brake Cleaner should do it.
Old Sep 18, 2020 | 10:59 AM
linderpat's Avatar
linderpat
yep, cosmoline. Some have used kerosene to remove it. I use lots of stiff brushes and simple green and soap. Note - Simple Green is very corrosive on Aluminum, so while it is effective, it must be washed off immediately with soap water. There is no quick way to remove the cosmoline. It's an intensive labor job, and for the underside of our cars, not really worth it IMHO.
