1/4 window removal gen2
Are you replacing the window gaskets? Or is it for another kind of install? I don't know how to do it but i heard all the glass has to come out to replace the seals and with most of the cars now hitting ten years it could be a popular repair shortly.
I may be wrong, but I believe the window seal (doors and rear quarters) is a single item that is riveted in place.
Yes that is correct. The window needs to come out and then you have to drill the rivets out that hold the trim in.
Also, you HAVE to make sure you get the rivet tails out from inside the 1/4 panel or they work their way down between the inner and outer skin and get wedged. They then push out on the outer skin over time causing outward protruding dimples
Think I have sorted this.
Will write up how you do it tomorrow.
I have the B trim off - does anyone know how to remove the C trim? Can't seem to find a clear guide how to do it and what the clips are like
