removing spoiler, return to original?
What would it take to remove spoiler and return to stock--time? money? Worth the effort? I haven't seen this in person, and am considering purchase.
Thanks . . .
Thanks . . .
Depends on how it's mounted. If they drilled holes, $$$$. If not, it would take maybe 20 minutes and zero $ to remove. Keep in mind too that you'd likely recover some of any expense associated with removing it by selling it here.
Good luck!
Good luck!
Another consideration might be the reprogramming needed to recognize the functioning of the stock spoiler to deploy at whatever the factory setting is.
This will require a PIWIS, Durametric Pro, Foxwell ??? or similar devices. If the only option you can find is the PIWIS at a stealership, then the price will depend on the mood they're at that day... which could be $0 or 1-2 hours at whatever their shop rate is. Realistically it really should not take more than 15 minutes but my original caveat still holds.
