Ticking 997.2
Old 08-11-2020, 07:11 PM
snaphappy
snaphappy's Avatar
Default Ticking 997.2
Here's a video of my ticking sound. The ticking sound increases with engine RPM. This only happen when oil temperature is at 200 and above. Please ignore any moisture you see, it was raining. Some people say it's just the DFI - but it didn't tick like this before. Some people say it's the valve lifters, when they get hot they tick... @conceptDawg do you think this is normal? @Bruce In Philly what about you? @Charles Navarro what do you think? PS - this car has never burned a drop of oil. But this is my first time using LiquiMoly. Maybe I'll put DT40 back in and see if it goes away.
Old 08-11-2020, 07:19 PM
Charles Navarro
Charles Navarro's Avatar
Received 1,113 Likes on 583 Posts
You will know best. The DFI cars do tick, but if it didn't make the noise before and it now does, something had to have changed. Did it immediately start making the noise after the oil was changed? It's quite possible that the new oil is lower viscosity than what you were running previously. Which LM product was used and did you add any Ceratec by chance?
Old 08-11-2020, 07:34 PM
snaphappy
snaphappy's Avatar
I went from DT40 to Liquimoly Leichtauf 5W40 with 1.5 bottles of MoS2. I didn’t have enough DT40 for the oil change So I drove to Napa, bought the Liquimoly and then did a three day rally in the mountains. I now have two cases of DT40 so I won’t run out again 😂
Edit: to answer your question, the ticking started day 2 of the rally after some VERY hard driving. We were at 4krpm+ for 6 hours/day for 3 straight days. But again the ticking was only audible when the oil was 200 or hotter
Old 08-11-2020, 10:21 PM
bgoetz
bgoetz's Avatar
Yeah that definitely does not seem normal to me ☹️
Old 08-11-2020, 10:38 PM
Crowndog1
Crowndog1's Avatar
Sounds like something rattling in the exhaust system?
Old 08-11-2020, 10:57 PM
TheTorch
TheTorch's Avatar
hold on... @snaphappy, didn't you just have your HPFP changed recently ?
Old 08-11-2020, 11:06 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,536 Likes on 925 Posts
2009 C2S 157K miles
Get a stethoscope and start poking around.
https://www.harborfreight.com/mechan...ope-63691.html
Peace
Bruce in Philly
Old 08-12-2020, 01:00 AM
snaphappy
snaphappy's Avatar
Yup, less than a week ago. Sound is on the same side too. But I didn't think they were related
Old 08-12-2020, 05:12 AM
Centerlock
Centerlock's Avatar
I have a very similar noise when lifting the throttle and slowing down on my 2011 GTS. I believe its something in the exhaust/cat.
I can try to make a video of it this weekend.
Old 08-12-2020, 08:32 AM
Charles Navarro
That is a very important fact that was left out in the original post. Was the oil changed at the same time?
TheTorch (08-12-2020)
Old 08-12-2020, 08:37 AM
Charles Navarro
This does sound viscosity related, especially as it doesn't make the noise when the oil is cooler than 200F. I'm guessing the hard driving coupled with the fact that the MoS2 additive was used. If the MoS2 additive is thin like the Ceratec, it will lower the oil's viscosity.
Regardless of the fact the HPFP was changed out as I've just read, I think changing the oil out is the first step.
Old 08-12-2020, 09:42 AM
Petza914
Petza914's Avatar
Received 6,453 Likes on 4,114 Posts
Hope an oil swap fixes it. I think we talked about the oil situation before you headed off to the rally and I recommended leaving the DT40 in rather than changing the oil. From the "Another Used Oil Analysis" thread, the LiquiMoly numbers don't look all that great.in one of the samples even on a low mileage engine (JustinCase) as it had high Iron & Copper wear metal ppm #s at the 5,000 mile change interval, and that was with one of LM Moly additives. The other LM sample in the table looks good, but was also only run 2,600 miles.
I'd have left the DT40 in there. Not sure how well the base stocks of DT40 and LM play together so maybe do a flush with BR40, put the DT40 back in and see if the noise goes away.
I missed an oil change in my wife's car once and ended up going 7,800 miles on DT40. Other than the oil getting too acidic and the viscosity dropping lower than it normally is at 5k, the wear metals still were quite low.
Old 08-12-2020, 01:58 PM
Hindsight2010
Hindsight2010's Avatar
Definitely not a normal sound. There can be some very light ticking sounds on the 997.2 engine but it's constant - like light lifter tapping. Yours isn't constant, it comes and goes. So it's not that. And mine definitely doesn't make that sound.
Old 08-12-2020, 04:09 PM
Doug H
Doug H's Avatar
Ouch, not sounding good at all.
Old 08-12-2020, 04:58 PM
snaphappy
snaphappy's Avatar
I should’ve listened to you Right now I’m debating whether or not I should drop the oil pan as part of my oil change. Charles Navarro said I should drop it. Do you happen to know if there’s a reusable o-ring on the oil pan? Or do I need to reseal it with some silicon? Also how much do I torque the oil pan bolts to?
Quick Reply: Ticking 997.2
