Low oil warning - sensor issue?
Hi!
The low oil light comes on intermittently on my 997. When I check the oil and of course it's full, the light goes out. I suspect some type of sensor issue. Anyone else have this issue or know how to fix this issue?
Thanks for any feedback!
Hmm, good point. The gage shows all bars full but last year it was the same measurement and it only lit up once. Some days it won't do it and others it could light up a few times. The car doesn't use any oil so I doubt the oil level will drop. I'll keep an eye on it and next oil change I'll make sure it's not overfilled. Thanks for the feedback.
I know it may seem like an obvious question, but nevertheless worth asking as you didn't mention in the first post.
What surface you are checking on for your reference? Are you sure it is level? The sensor readings are very sensitive to even minor changes in the angle of the vehicle.
Visit us online https://emc2design.com
By Porsche enthusiasts
For Porsche enthusiasts
I would watch your oil pressure. Is it behaving normally? I am thinking the sending unit might be bad. Mine was bad and it had the opposite affect, always high pressure. It a cheap and easy fix. Took 30 minutes.
Send us a pictore of the dash oil level when you check it. Are you sure the warning you're seeing is low oil level and not a high oil level warning? You're going to need to measure the amount that comes out at your next oil change just to know. The senders do go bad though. If you turn the key to check the level, what pressure does your oil pressure gauge show without the car running?
Overfull, is a good way to foul plugs and damage the AOS.
All great points. Next time it goes on I'll take a picture and post it. My gage shows one bar above the example on the left. It could very well be slightly overfilled. Thanks guys, I really appreciate the feedback. I'll report back on my findings soon since I have a 100 mile plus trip planned for tomorrow.
I would drain some oil first..... Your one of the few who actually got a light from overfill....
You can't get a hose down the oil filler or the filter housing... I tried.
Peace
Bruce in Philly
Peace
Bruce in Philly
Same here. I have a 2009 997.2 S with 23000 miles. Occasionally the check oil light comes on. I just reset it and get it measured again then all is good. I gave up to worry about it.
