Detailing clear wrap
I like to wash and wax my own cars and my 997 presents a different challenge. It’s got the clear protective covering on the front bumper, fenders, mirrors, doors, door handles and rear quarters. I normally just wash these areas and they look good, but is there a polish or wax I should be using on them?
Thanks, Perdido
Thanks, Perdido
Received 5,407 Likes
Perdido (06-13-2020)
Thanks, Perdido
Thanks, Perdido
I have always treated PPF like paint. On my 997 the entire car is covered in PPF, it's ceramic coated and treated exactly like paint. I have my daily driver that has PPF as well, treat it like paint and hasn't yellowed.
I have PPF on my cars. I've done a ceramic coating over one of them and it went on and looks great. On the other car I applied a polymer sealant - and that looks good too (won't be quite as durable as the ceramic, but quicker / easier to apply.) You can also apply wax (as conveyed via the link earlier in this thread) but wax usually breaks down pretty quickly. As a prep to using any sealant or wax, you can use paint cleaning clay along with a spray detailer to clean any accumulation of surface contaminants off of the PPF. I don't think I would opt to use any polish (abrasive) on a PPF though. You really should not need to anyway.
Which polymer sealant did you use? There are so many choices...
Thanks, Perdido
Perdido (06-14-2020)
I recommend Jescar Power Lock (formerly called Menzerna Power Lock). Really great stuff. Easy / quick to apply. Durable. Great shine. I've used it for over six years and I'm always satisfied with the results.
https://www.amazon.com/Jescar-Power-...NsaWNrPXRydWU=
If you do choose to go with Power Lock, it does not need to be left on the surface long prior to buffing it off - just a minute or two is fine. You can buff it off with a high quality microfiber polishing cloth (16" to 18" square is good.)
As alpha says, just treat it like paint.
Regarding the application of sealant or wax on PPF - one thing to consider when applying it is to be aware / sensitive to edges of the PPF - where the PPF and paint meet. The video below has some good tips on this.
(Perhaps you may wonder why this is even a point of consideration? If you get sealant or wax applied along the PPF edge, when it fully dries, it will leave a white residue that accentuates the PPF edge.) You can avoid that by using the technique shown in this video.
Perdido (06-15-2020)
