Which 997 model?
I’m doing some early on research on a possible future 997 purchase. Which 997 models are available…….
WITH: wide-body, NA engine, PDK, sport adaptive seats, chrono, and PASM
WITHOUT: IMS issues
Any drive (RWD or AWD) would be acceptable at this point.
WITHOUT: IMS issues
Assuming we aren't talking about GTS, GT3 or GT2...
- Wide body will only be your "S" models.
- Normally Aspirated stopped in '16 with the 3.0 turbo.
- Practically no IMS issues after about 2006 (though depending on who you ask, Bore Scoring is the new boogeyman).
- PDK started in '09, so if that's a deal-breaker, 997.2 and subsequent models.
So it sounds like you need between an '09 and '16 S or 4S. Of course, I'm new here so I may have mis/understated some of the above.
Good luck with your hunt!
WITH = 997.2 4S Carrera 4 & GTS & GTS 4 2009-2012 I might be forgetting Targa models also
WITHOUT IMS = 2006 & on however this does not meet your WITH requirements
Hella-Buggin' (06-08-2020)
Arctic997 (06-10-2020)
Understood. I thought the IMS problem was addressed by Porsche at some point. I was hoping that would coincide with the release of the PDK/997.2 (2009 & onward).
Originally Posted by Radman73
I thought the 4 and 4S models were wide body and all others narrow on the 997?
The GTS is wide body and RWD
If I read correctly {its been awhile} sometime in 2005 Porsche started using dual row IMS bearings. But those are still prone to failure, but not as often. Do some research.
Not only does the .2 not have an IMS it has like 40 percent fewer parts too. The only way to get a wide body is the gts, 4 wheel drive models including the targa and turbo. The only way to to get a RWD wide body car is a gts.
IMS Dual Row bearing 1998-early-mid 2000. rumors claim very small chance of failure. 2-4%
IMS "Small" Single Row bearing "boogey man" 2001-2005 rumors claim 7-10% chance of failure.
IMS LARGE Single Row bearing "the fix" 2006-2008 rumors claim 1% chance of failure.
2009-2012 new engine design No more IMS bearing.
Not quite... dual row was early 996 986 years.
