Boosting midrange
Boosting midrange
Hello Renn peeps
i hope everyone is well.
I was just wondering if there’s a cost effective way to boost the mid range on a 997? Top end seems fine but I don’t spend all my driving bouncing off the rev limiter.
is it via a software, exhaust or intake?
just curious.
thanks
mike
just curious.
thanks
mike
Edit: I assume you are talking about a naturally aspirated 997 when I wrote the reply below. If you are talking about a turbo, just a tune will give you solid gains.
In terms of seeing a real, meaningful increase on the dyno that you will really, actually feel, the only option is a supercharger (though I would not recommend this). All the other mods like headers, cats, x-pipe, mufflers, intake, tune, etc.... these mostly make more power at high RPMs, the mid-range gains are so subtle you wouldn't feel them, and you'll throw $10k + for them.
A lot of people will add louder intakes and louder mufflers on their car and the placebo affect will cause them to "feel extra midrange power" but IMHO that is psychological. On a mid 300hp car, you are going to need a solid 30-40 ft/lb or more torque gain at a given RPM to actually feel anything. You won't get that with exhaust and a tune. I've never seen a single, independently tested, dyno sheet showing a midrange gain of 30+ ft lbs of torque in the mid-range on these cars. Except for a supercharger.
Best to just enjoy the car's power as it is and if you want more mid-range, sell yours and buy a Turbo model instead. Lots of midrange torque with those and they provide much bigger gains with a tune.
take care
mike
I did intake, exhaust and several custom tunes. Car seemed to spool up quicker with some better top end. Shop that did the tune said 20 hp. But, still the same low end with soft spots in mid range. On the whole, it wasn't worth $10k.
Hindsight2010 (05-19-2020)
As stated, you won't get anything noticeable in the midrange without forced induction.
Hindsight2010 (05-21-2020)
