Burning smell when driving "spirited".
So I'm on my 4th month of ownership. Love the car, still ironing out the do's and dont's. I have noticed on several occasions when the car is pushed a bit the oil temp creeps a tad above 200 which I assume is completely normal but I also notice a very noticable burning smell. Inside and outside of the car. No smoke but the smell really makes me nervous. Car burns no oil, tailpipes are spotless, does'nt smell like oil burning. Zero oils leaks so nothing on the exhaust. Now this is ONLY if I push it a bit and not necessarily hard even for a short period. Im clueless. Any clues?
Someone else asked this recently too. The explanation that makes the most sense to me is that tires expel some rubber particles on the mufflers and they get hot and create the smell. Personally I enjoy that smell
Or cosmolene (or other shipping protectant) that takes about 75K miles to burn off of the motor and exhaust.
I've found that the smell (aka Porsche perfume) eventually goes away. And yes, I do kind of miss it.
The following 2 users liked this post by Wayne Smith:
dmpslc (01-13-2020),
JustinCase (01-13-2020)
I agree with everything above. The tires smell more because of their closeness to the engine and exhaust. There is also a unique "porsche cologne" emitted even when I just drive a couple miles. It is clearly from the engine and exhaust. I do not see these smells as abnormal but they are unique to the 911. Every car I have had has different "normal" smells that would trip me out at first but then I would get used to them. Also, problem smells are more standardized. A burning clutch smells like a burning clutch on a hyundai and on a porsche IMO. <---- maybe the porsche one smells better, lol...but the unique smells given off by this car are my tires smell like they do after some track driving even when I am just going to the store for some groceries, and there is clearly a proprietary coating as mentioned above that has a unique smell. My car is just shy of 25k, so I think it will be there for a while longer.
Prestige_Swiss (01-05-2023)
Burnt smell after hard driving
All the replies are wrong so far. It is the clutch pack inside the transfer case burning, trying to send torque to front end. Change your fluid and add ford motors co. friction modifier to the fluid. It may be too late for that depending on how burnt it is you may need a new transfer case, or replace clutch pack if you can find new clutch pack. I don't think they sell new clutches as I need one but can not find it anywhere
All of the replies (previous to yours) are the ones that accurately depict a typical 997 characteristic.
Ironman88 (05-30-2022)
