Turbo car questions from potential buyer
Sports Exhaust button was option right? Even on Turbos? The original owner had to purchase the option when ordering the car.
Im guessing very few people did go for that option BECAUSE the Turbo has a very quiet exhaust. You don’t need a button to make the exhaust even quieter 😂 The exhaust note is often described as pathetic until an aftermarket exhaust is installed. And PS those are pricey.
The turbos seem difficult in terms of exhaust note. Even with some after market exhausts I've heard. Better than stock but still lacks the Porsche grunt to my ears. Maybe I've haven't heard the right configuration yet.
I really like the sound of my GTS at higher revs. I need to look and see if it has an X-Pipe or something aftermarket. I just like the way it sounds and don't care if it is stock or aftermarket enough to get down on the floor and look.
There are aftermarket valved exhaust options for thr turbo cars. Other than the coolant pipes, you also have to check that the cam gears have been addressed so they don't spin and get out of time.
Rocky Mountain High
I think you’re right. My 996 C4S with Fister mufflers had the best exhaust note of the three 911s that I’ve owned. My 991 turbo with FVD exhaust sounds better than the OE exhaust, but not as good as a normally aspirated car.
This 2013 997.2 tt I heard the other day had a glorious deep rumble and sounded very cool IMO at idle and lower rpms. It did not hear it in the upper rev range. The owner swore up and down the car was all stock.
