3rd radiator airflow
On a regular 911, the side radiators have air passages for heat exchange and then channels it out through the wheel wells. The 3rd radiator on the GT3 also have an air vent on the top of the smiley face to dissipate heat. For our regular 911, if someone wants to install a 3rd radiator, where does the airflow go ? If there is no means of airflow for heat exchange, then even on highway speed I can't imagine how efficient the 3rd radiator can provide. My question is what is the point of adding a 3rd radiator if the backend is blocked with no air passage. Anybody that installed the 3rd center radiator care to give some comment on this ?
I understand that there are 4 square indents in the tray below, which you need to cut out to allow extraction of the air. There is a thread here somewhere with a photo if you want to look
Yep, GT3 goes out the upper smile vent. Regular Carrera goes out the bottom.
Basic Sponsor
With the aerokit front bumper on mine I did not need to cut any holes as there is a 1 inch(?) gap at the back of the bottom cover.
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Ohio Clothing
