So, it's getting close to that time of year again where I swap on the winter tires. I now have dedicated summer wheels/tires, so the stock Turbo II's will become the winters for now.
At some point the previous owner got a blow-out, and had one of the wheels refinished (or all of them possibly, as they're solid platinum/gray versus the cut finish on the fronts that appear on most). With several tire changes, there are a few chips in the paint. Long story short, I want to refinish them before getting the winters mounted once again.
Does anyone know what powder-coat color is closest to the factory color (or even the paint code)? I like the color, but don't want the center-caps contrasting because they don't match.
Reason: picture
A good wheel repair shop will have the paint code. Also a good idea to match it up in person with them. I found quite a few variations of what I thought was a straight forward color.
We just did ours on the 981 Cayman. Last night as a matter of fact! Don’t know that grey code though. Here are some photos. Some fine line, painters tape and matched paint and clear. I only did a color change if the inserts. The refinished wheel was done in platinum silver not GT silver so I changed it to match
Silvers and metallic grays are very difficult to match and it is best to start with the "right" code and then visually check a few adjacent examples for the best match. But since you are powder coating all 4 from scratch, as long as you're not trying to match the body color you should be fine with what they provide as the factory code. Or just choose the one you want.
The issue is that there are a few different manufacturers, so not knowing what their system is, I don't think anyone can give you the correct approximate match. Even if you look it up, you might get more than one suggested match.
Wheel paint vs powdercoat?
Winter wheels? I say paint. Easy to patch and repair.
If you are really driving in the snow and salt and sand? They need to kept sealed to avoid peeling and corrosion under he surface.
Powdercoat is much more durable than paint. With wheels you need to use a low-curing temp powder so the wheel doesn't have to be baked as hat as that can damage the structure of the wheel. I think I remember 300 degrees as the temperature limit.
