Steering Wheel Mod
#46
not sure if you'll see this, but I think i found the same one on Amazon. Did you have to contact the company for a wrap specific to your wheel? I've got the triangle airbag and didn't see anything close enough, but this is by far the best DIY wrap I've seen. Would like a Macan wheel but don't feel it's worth 600 or more then sourcing an airbag separate.
#47
How about this?
https://rennlist.com/forums/market/1261625
#48
groovzilla (01-04-2022)
#52
Did you opt to keep the Sport Chrono ****?
Does anyone know if the **** is mounted on the frame of the wheel or if it's mounted on the trim pieces?
I'd like to find the same wheel, but I don't want the SC ****.
Removing the **** will either lead to two options:
1. **** is mounted to the trim piece and I'll need to order trim piece without the ****
2. **** is mounted to the frame of the wheel and removing the **** leaves a big hold in the plastics
If anyone has removed the SC **** chime in please?
Thanks!
Thanks!
#53
Irishlegend
i paid $825 shipping. It will probably not cost you as much as mine did. I did not want to give Donald my OEM wheel. I wanted to keep it. Donald Le is great to work with. Shop with confidence when working with him.
good luck with your decision.
IrishLegend (01-05-2022)
#55
Hmm. I’m getting a little bit of a binding noise now after replacing the wheel. Sounds like the back of the wheel and the steering surround are touching each other. Only happens about 20% around the wheel.
My guess is the surround needs to be moved a little back.
#57
Basic Sponsor
I'm trying to order one from him, and it's like worse experience ever... He answers in 2-3 days, and then he always answers only first question, so I have to write again and then wait 2-3 days again... It's been like 3 weeks and I still can not get an answer how to pay... I'm about to give up... Is that's the usual experience with Ledermanz?
T-Design9 : Mods and ergonomic accessories bespoke designed for Porsche cars
Memory Modules : remember SC **** settings; A/S/S, PSE, Spoiler, Sport/+ buttons
Phone Mounts : keep your phone up and close and charged
Cupdholders, Sunglass Holsters and more at T-Design9.com
