Clanking sounds when revving from low rpm
Old 09-08-2019, 10:38 PM
retlas
retlas's Avatar
Default Clanking sounds when revving from low rpm
Hi guys
i am noticing a pretty loud clank when I hit the throttle from <1200 rpm
You can hear the sound at 10, 12 and 14 seconds in the below audio clip.
2007 997 4S
Any ideas?
https://www.dropbox.com/s/yfzqa2klk8...d%203.m4a?dl=0
Old 09-08-2019, 10:52 PM
groovzilla
groovzilla's Avatar
Received 4,481 Likes on 2,732 Posts
I thought I also hear a slight similar sound at the 4 sec mark.
Almost sounds like the lag sound (valve tap) when you are in too low a gear and put stress on engine
Better qualified will give input I'm sure.
Old 09-09-2019, 12:22 AM
snaphappy
snaphappy's Avatar
Does she burn oil?
Edit: after you figure out what the problem is you might want to consider switching to 5W oil if you’re running 0W. But don’t start with that. Leave everything like it is until you get it diagnosed. Smarter people than me will chime in shortly.
Old 09-09-2019, 06:31 AM
TheBruce
TheBruce's Avatar
Do you live in California? If so its engine knock from the 91 octane, at least thats the best explanation I got.
I had a similar knock blipping the throttle below 2k rpm when I first got my car. I solved it by not blipping the throttle below 2k rpm anymore :-)
Old 09-09-2019, 08:51 AM
Petza914
Petza914's Avatar
Received 6,263 Likes on 3,989 Posts
Take a look at your motor and transmission mounts. Sounds like the initial torque of the motor when you hit the gas is causing it to contact something metallic, maybe a coolant pipe like those that fastened around the oil sump or something near an exhaust component.
Old 09-09-2019, 11:29 AM
retlas
retlas's Avatar
Thanks for the reply, and nice ride. Mine's arctic silver as well.
Old 09-09-2019, 11:30 AM
retlas
retlas's Avatar
Does she burn oil?
A little, about 1L per 1,200 KM, which from what I understand, is normal.
Old 09-09-2019, 11:31 AM
retlas
retlas's Avatar
Hmm, the local station only has 91 - but the Shell station has 93. It's a good idea and I will fill up the next time with 93 and see if it makes a difference - thank you.
Old 09-09-2019, 11:32 AM
retlas
retlas's Avatar
Hi, I had thought something similar and just replaced the engine mounts as I had inspected and found about a 8mm drop on the right side of the engine. The new mount leveled things back up but didn't stop the noise.
Old 09-09-2019, 12:52 PM
TheBruce
TheBruce's Avatar
Keep me posted if the 93 helps. That would put the mystery to bed, as @Petza914 's comment just put my OCD into overdrive :-)
Check out this post from 2008 where a lot of people reported similar thing. I resurrected it when I first got my car.
https://rennlist.com/forums/997-foru...e-knock-2.html
Old 09-09-2019, 01:08 PM
Petza914
Petza914's Avatar
I had another thought on this - is it only happening on cars with the factory airbox? I'm wondering if it is the Helmholz resonator in the airbox snapping shut upon throttle blip due to the immediate increase in air requirement from the quick throttle press. Someone with an automotive stethescope could put it on the resonator in their airbox while someone else blips the throttle and see what they learn.
I have never heard this in either of my 997.1 C2S cars and I'm wondering if that's because I don't run the stock airbox - the supercharged car has a Fabspeed J-Pipe intake and the other has the Evoms, which is what got me thinking about the resonator in the stock airbox.
Old 09-09-2019, 01:54 PM
TheBruce
TheBruce's Avatar
No, as the C2 doesnt have the variables baffle in the resonator.
In mine its definitively a metallic sounding "clanking", as the OP described.
Old 09-09-2019, 01:55 PM
Petza914
Petza914's Avatar
Hmmm. OK
Quick Reply: Clanking sounds when revving from low rpm
