997.1 2006-2008 M97 serviceable IMS
Is EPS the only IMS solution for M97 that does not require a tear down? Is there any information on why the approach they use to gain access to service/replace the bearing is not done by others? It seams like a viable option when comparing to the alternatives of doing nothing, removing the seal or tearing down the motor.
Please read all the information out here. Basically it is not necessary to change in terms of statistics and cost benefit. The incidence of failure is extremely rare on the larger more robust bearing, and I believe Jake Raby has stated this relative to non tracked cars.
I am the Walrus (08-26-2019)
Yes, I have read a a bunch from Jake. I would love to replace my IMS with one of his. As it stands right now that is not a realistic option. My question is why not? Why doesn’t he or LN recommend not boring out the block to gain access?
The concept to access the bearing seams reasonable to me. Maybe others who know more can explain why it’s not?
"Why doesn’t he or LN recommend not boring out the block to gain access?" From what i understand because of the risk of having the fine metal from the boring getting into the engine. Also, note that poll is unscientific and misleading.
Yeah, I considered the debris, however the old bearing is still in place and sealed at that point. You don’t bore out the bearing, only the flange to gaining access to remove it. I certainly recognize this is not the most elegant solution. But again it appears to be the only one aside from prayer or a tear down.
Former Vendor
The last engine I saw with a bored IMS access port lasted 900 miles after the procedure was done.
We've seen a few of these, and due to it we had to make a special oversize IMS Solution flange adaptor to address engines that have had this done.
Debris should be avoided at all cost, the lightweight aluminum debris that suspends easily in the oil, and is then delivered to all internally lubricated components within the engine. "Fixing" one problem can create dozens more.
We've seen three M97 IMSB failures since 2006.. That's right.. Just 3. The best course of action is to service the engine frequently, remove the grease seal when you do the clutch, and just drive the damn car. We leave these alone from a preventative perspective.
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_3936_27a71d41391b4b0c32939ea987ee65f605919884.jpg)
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_3940_668a5e960c34d026ad4d9b826003ba2dab5c58c5.jpg)
![](https://cimg0.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_3935_c04e719894042d8a552132b1dcb8c66351e0d5ab.jpg)
![](https://cimg5.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/img_3941_e0c0a90775d5013d976d3fc639fdd9d1f2b4debb.jpg)
Yes, I have read quite a bit including the poll that clearly has cars in my category listed in it with IMS failures. I understand that my car has less probability of a failure. Much like other owners I want some peace of mind that my car won’t detonate.
Maybe a Toyota is a better ride for you.
Just sayin.
The motor rebuild for my car is the cost of a brand new toyota.... just saying.
thanks for such helpful information.....
Prevention and research on a non issue for 99% of 997 owners of 2006-2008 cars, as stated by the foremost expert on 996/997 engines in the USA and could be argued the World said as much.
Move on to bore scoring and oil suggestions to prevent scoring. Now this is a rich subject worth researching.
Good luck on Trans removal.
Out.
Out.
