Change Canadian DRLs to fog lights? 997.1
I am curious why you need a diode hack for activating the fog lights. I have a US spec car and my DRL's were never activated for some reason. So when I want DRL's i just click the headlight switch over 2 spots and pull the switch out one notch = fog lights activated
What is this diode hack? My 911 is a Canadian car and I had SpeedStar code the DRL out and I spliced a couple of wires in the light switch so that the fogs will always come on in “home” mode. Easy peasy. I don’t remember which wires were spliced...
Saw this post on another forum. I've considered doing it myself, but will probably stick with the low-beams as my DRL's as my car is low and hard enough to see as it is.
$2 DRL Solution
$2 DRL Solution
Speedstar does the coding for this? Is it the guys located on Bullock Drive in Markham?
This is EXACTLY what I want to do. I have a 987.1 and PCM 2.1 (so I have no access to the DRL) - I'll have to pick up a Durometric Pro and give it a go. Are there any links for the 'diode' solution?
Thanks!
Thanks!
