Blasphemy... more comfort!!?
I have a 997.1 C4S and will be replacing all 4 dampers. Is there a damper option that will increase my daily driving comfort without compromising the sport??
so, I am assuming you have PASM with the C4S. Your budget matters a lot but I would also argue that a controller such as the DSC unit would allow you to tune the suspension more specifically to your liking. If you did not have PASM, you could manually do something similar with coilovers like KW V3 or Ohlins R+T and mess with settings + springs.
I think If I wanted to retain PASM and I was in the market for replacement dampers, I would look at Bilstein Damtronic coilovers (expensive) or Tractive Coilovers (expensiver) with a DSC controller.
https://www.dscsport.com/product/tra...97-rt-package/
BTW, I have no connection to any company but I just think about suspension, a lot...like way too much. It is the one thing on cars that I cannot seem to get to be exactly as I want it to be ever but I can get close.
I am interested to hear what other people think though, especially non-coilover options.
"Bruce in Philly" installed a DSC module and it appears that he loves it. https://rennlist.com/forums/997-foru...y-opinion.html
YOu could probably PM him for more info
Another vote for the DSC controller. I have a full track suspension setup in my car including Bilstein B16 Damptronics and RSS Tarmac Series stage 2 - no rubber bushings left in the suspension at all and with the customization (softness) available via the DSC controller, the car is still perfectly comfortable for around town driving and long road trips, and with a press of the Sport PASM button a mountain attack weapon. Don't give up the PASM functionality and add the DSC.
Another vote for the DSC before anything more intrusive. I installed it in my 997.1 C2S, and it made a very nice improvement in around town driving. The installation of the required accelerometer was a bit of a pain, but worth it.
Yep, still loving it. In short, it makes the ride more refined. Softer around town but no roll. Stiffens the particular shock as needed. Excellent product and a heck of a value IMO. The tuning ability is nice, but not at all neccessary... they have it tuned pretty well from the shop.
I am serious about this: If you have PASM, you should buy it and try it. If you don;t like it, sell it off for minimal loss. Installation takes 5 minutes, no tools, and does not damage the car at all.
Peace
Bruce in Philly
Peace
Bruce in Philly
I have DSC on 997.1S and am in total agreement with what Bruce wrote above about the ride but it took me a lot longer than 5 minutes to install
I just drove 10:44 hrs today, over 664 miles of the most beautiful land in this country. And I've got about the same on the menu tomorrow. The roads however, are not the smoothest.
I can absolutely sympathize.
Assuming you've worked on tire pressure first. You should be on the low end of the load range for comfort or even just a little under.
I would also stick with the stock PASM dampers, and add dsc first.
If that is still too stiff, I would actually recommend blasphemy. Replacing the sport spring with the base spring would I think be my next move if you can verify the base spring has a lower spring rate than the sport spring. I would expect it to be lower since it sits higher, but I am not 100% certain. Folks say the base suspension rides harder than PASM set to normal, but the dampers could be the reason. I am also not 100% certain that the base spring would sit properly in the sport damper's spring perches. But you should be able to find a takeoff set of base springs no problem and very low cost.
The DSC will change the damp behavior, but to really improve high frequency bump response one needs non-linear springs with a soft top.
+1 on DSC Sport Controller
Recently drove well over 2,600 miles in 2 amazing trips including spirited driving segments on the Lillooet Loop (British Columbia) & San Francisco to Vancouver via the coast. Out of the box, the controller gave me a softer comfortable ride on some horrid urban roads. On the flip side, my GTS never handled better through the continuous twisting roads and highways.
Ok. Good insights on the DCS module. Yes, I have PASM but I’m getting some clunking from the front shocks. They will certainly be replaced with something along with the rears eventually.
I will update the thread when I decide on what I will purchase.
Peace,
Bruce in Philly
I am also thinking of going the DSC route. Unfortunately my right front strut is creaking/groaning and inspection reveals fluid leak, so new struts are in order. Thinking Bilstein B6 damptronics plus the DSC unit would be the way to? Is front strut replacement a DIY project for a keen but not particularly experienced amateur. I did the Sharkwerks X pipe and plugs and coils/ VVT solenoid without too much problem (thanks to the great DIY instructions on this forum. Thanks Bruce!) and have a Quickjack lift, but the thought of needing spring compressors etc worries me a bit!!
