Will they fit?
Old Jun 16, 2019 | 04:14 PM
street rod's Avatar
street rod
Default Will they fit?
Will these RUF wheels fit a 997.2 C2? Spacers?
Wheel specs:
Front 19 x 8.5 x ET56. RUF part number R96 362 119 10
Rear 19 x 10 x ET66. RUF part number R96 362 120 10
Tires specs:
Front 245 35 ZR 19
Rear 285 30 ZR 19
Old Jun 16, 2019 | 05:23 PM
Kuhl997.2!'s Avatar
Kuhl997.2!
They will fit but the rear wheels will be a bit narrow, may or may not need rear spacers depending on how you like how the rear wheel fills the wheel well. 11 in rear wheels are pretty much the standard and there are a couple of factory styles that are 11.5 in wide.
Old Jun 16, 2019 | 07:11 PM
street rod's Avatar
street rod
Yea I love these wheels but not sure if the 10 inch narrower rears trade off is worth it. Thanks By the way where did you get the wheels on your car?
Old Jun 17, 2019 | 06:54 AM
Petza914's Avatar
Petza914
The 10" rear wheel is pretty much a Boxster / Cayman fitment. My C2S (NB) based R-Kompressor came with RUF wheels that were
Front - 8.5" x 19" with 58mm Offset
Rear - 11" x 19" with 70mm Offset and 7mm spacer (net et63)
Unfortunately they had been chromed and were super heavy so I sold them.
The fronts will fit but I'd actually space them out to around an et50, so a 7mm spacer. The rears aren't a good fit as they're too narrow to run a proper 911 rear tire in the 295 or 305 range.
