997.2 PCM Y cable with iPhone X
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
I have read what I think is every thread on this topic and thus creating this one. Recently purchased 997.2 2011 and cannot seem to get the PCM to play Spotify through my phone. I purchased a 30pin to lightning and after inserting a cd, downloading a track to Apple Music, the car will still not recognize my phone device after flipping through sources. Are there different types of 30pin to lightning? What am I missing here? Thanks for your future guidance.
https://www.newegg.com/p/N82E1683498...E&gclsrc=aw.ds
Here's the adapter that did work.
https://www.walmart.com/ip/Apple-Lig...hoCBw0QAvD_BwE
Best of luck to you! (My 997.2's PCM stopped working with any Apple device, and after taking it to a repair shop, I found the Y-cable's pins had been bent by the repair shop! Argh!)
clasik (02-07-2021)
clasik (02-07-2021)
I have an iphone 8 but the Bovee bluetooth dongle connected to the OEM 30-pin connector and it works fine for me. My phone doesn't always connect so I have to fidget with it sometimes but it doesn't bother me enough to seek out another solution.
I can't even get any of the AUX, USB or iphone output to come up on PCM. I even went to the dealer to update my PCM software but still can't get the AUX to come up on the screen. Any advice?
For an alternate POV, I managed to get a 30 pin-lightning from apple, connected it to my phone and while the sound comes thru, the quality is horrible. Anyone had that issue? For reference when I use a BT adapter to plug into the Aux the sound is totally clear
This is what I use in my 997.
https://www.aliexpress.com/item/4000...archweb201603_
Phone is always connected to bluetooth for calls but for spotify, i will plug this in, play music through aux and it charges my phone at the same time anyway
AUX and USB only come up as options if there is a device plugged in the car recognizes. I have USB plugged into mine, first time I plugged it in it didn’t show up cause formatting didn’t match car requirements. Formatted, loaded songs, and voila, it appeared on selection panel of PCM.
https://rennlist.com/forums/997-foru...usb-drive.html
You may have to reformat the USB. Below link should help with USB format and supported file formats. I had to reformat USB. If memory serves I also initially had some non supported file formats on some tunes which prohibited the PCM from recognizing the USB (I loaded couple thousand songs). Once I deleted the bad files, it worked immediately and has since. Let us know if this helped!
