Radio - Repair or Replace
Opening topic for 2019 discussion. Car is 2009 CarreraS with Bose and the PCM 3.0 is starting to having some issues...rebooting periodically. So, I see 2 options:
1. Repair the head unit to the tune of about $1k (still don't have Pandora streaming, apple play, backup camera, etc.)
2. Replace headunit using Nav-TV integration for a little more in total all in cost (gets newest technology, backup camera, etc.)
Let the opinions get started. Would love to hear thoughts and experiences by those that have done option 2 with keeping the Bose amp and speakers and if there was any change in sound quality.
Thanks,
-Skip
Thanks,
-Skip
Skip, there are at least 2-3 very recent threads on this with multi page entries. I think anyone who has an opinion on this topic has prob made it known there. Might want to check those out
Cheers
Cheers
2009 C2S 133K miles
If you change the head unit, assuming you have the Bose premium, you need to replace the amplifier (located under the passenger seat). All speaker cabling for this 5.1 DVDA system terminates under the passenger seat at a processor/amplifier. It speaks a proprietary protocol to the head unit.
Peace
Bruce in Philly
Peace
Bruce in Philly
The PO of the car I purchased recently spent about 2k on a headunit, amplifier, and installation to remove the Bose system.
He did NOT have the subwoofer connected to the system and while it doesn't sound terrible it definitely sounds pretty hollow.
The sub has it's own amp and all it needs is signal from the headunit to turn on - this is a relatively easy thing to splice into the harness and I'll be taking care of that shortly.
I think this is a pretty good route to go...
2009 C2S 133K miles
Peace
Bruce in Philly
Peace
Bruce in Philly
http://www.connects2.com/home/index
http://www.connects2.com/Product/ProductItem/CT51-PO04
Becker audio repairs them I think for about $500, but thought they were in NJ.
I had just reopened a thread just Monday about the issues I'm having with my 2005 Carrera with Bose and the is updated to PCM 3.0 ...rebooting. Shortly after getting the car a couple years ago I added the Navigation and the LA MOD for the phone Blu-Tooth function and it worked fine for about 6 months then the NAVigation started to drop in and out, so I updated the PCM from 1.0 to 3.0 along with the Maps Set, and it appeared to work fine, then the NAV started to act up again. The Sunday the Head unit it started to reboot... no control function from the unit buttons. So I'm looking into the options as well ... wanting to feel out the community for thoughts and ideas. From what I have gathered no matter what the car will end up at the dealer to reset the PIWIS coding.
As much as I hate the idea, I guess I'm just getting myself psyched up for a $5K repair bill because no matter what I do the dealer will claim they had to replace the entire system because ... "PIWIS coding reasons".
Do a test to see if your issue is the same. Go into the phone tab, then options, bluetooth, and turn off the bluetooth function. Drive the car a day or 2 if the problem had been very repeatable and if so, see if it no longer happens. Then reenable the BT function and see if if starts doing it again. If so, tell the dealer you only want them to update the PCM software. If you're on the current version, ask them to delete it and reload it. They charged me 30 minutes labor to do this, which was much cheaper than any PCM replacement option.
Good luck.
I dont know about the 3.0 but in replacing my 2.1 there was no dealer coding reqd
Yes, I have reached out and read the other threads that I could find and chased what seemed like a limitless number of links reaching out to optional units, service locations, etc. The coding has to do with the hardware: for example:
PCM Codes:
SW version 3.0
PCM: 05024AD1 / 0205 ==> Model Level B
System Software: 04514BD1 / 5104
Amplifier: 00017500 / 3504
> Not Expected BUT Found = NAV System: 00179436 / 3306
CD Changer: C38 / 3003
> Not Expected BUT Found = Phone: C32 / 2702
The PIWIS coding would reset the system to Expect the NAV and Phone.
As for disabling the Blu-Tooth, the controls on the Head Unit are unresponsive and since the system does not boot completely I can not interact with the system. I do plan on pulling the unit this weekend and re-seating all the connectors and inspecting the cabling both electrical and optic.
I have the two firmware updates so I could also try doing a reversion back to 2.1 and see if that helps, but without a PCM that boots into an operational state this might be a pipe dream.
But will keep this updated as to what I find
PCM Codes:
SW version 3.0
Yep, lots of threads already on this.
But you forgot option #3
https://www.suncoastparts.com/produc...367100A05.html
Yeah, that replacement cubby is really cool and I didn't know it existed. I always wish there were a way to get rid of the center stack altogether, and move the climate controls up to the dash like in the air-cooled cars.
