So are the PASM connectors directional or not!?
I've read conflicting statements. When you disconnect the PASM wires, I didn't realize it had a tab on both sides, meaning you can connect it back in either direction. There is a 1 and a 2 on either the male or female plugs, inside the plug. Does the direction matter or not? Both numbers read 1 to 2 from left to right, meaning I would have to invert either one to make the likewise numbers match up (one set of numbers would be upside down)
Just want to verify I won't have to remove the Bose box and all that if I plug them in the wrong way. Thanks!
I'm editing my response here. Everything I've read says they are non directional and I've even experimented by swapping one with no effect. However, the design of the tab uses poka-yoke and is clearly intended to be inserted in one orientation as you can see in your pic. So probably best to connect them the right way.
I have always heard that they were as well. I was careful when taking mine apart to note how they were oriented so I could put them back together the same way. I've heard if one is reversed the suspension will log an error and go into full stiff mode all the time.
Looking at page 4370 in the manual it doesn't mention any direction. That section is about splicing and replacing the pigtail if need be. I figure it it would say it anywhere, it would be there since that section is specifically about the connector.
I'm going to align the numbers, but I don't think it's going to make a difference. The way the struts work, it doesn't make sense for it to be polarity sensitive anyway. It seems like it just needs a completed circuit for them to work.
