Check engine light help
Sorry, yes, it would be the crankshaft position sensor in your case and there is only one. That's also the one that makes the tach jump on the 0 during starting.
I threw you off with my Durametric screenshot and reference to the camshaft position sensor.
Looks like a critter/rodent chewed completely through the crank position sensor wire, both ends hanging in the breeze. A couple nibbles on the wires plastic bracket too. New sensor should arrive tomorrow morning.
My 06 997 s with the x51 package has had 2 episodes of the check engine light and take to repair shop message. Dealer rand all the tests and reset ECU. Car ran great until I took it north for a 3 hour drive. After a lunch break the same noice came on and in my mind the car ran a bit sluggish at 3800 rpms in 4th and 5th gears.
I have a 2013 911 carrera base model. I recently got a check engine light that said engine control fault driving permitted. It has almost 34 k miles on it. The battery is 8 years old. Could low voltage throw these type of things? Never had any problems.
