My new indy scratched my seat...
Just lick your finger and rub it out - No big deal
OR
Sell your car and UBER
OR
I drive my car every day, but if somebody damaged my car, I'd want it fixed. There's nothing wrong with investigating options on how to get it done or do it himself.
If you don't mind other people tearing up your stuff, that's cool.
I've got a solution (serious - not joking):
I've got a pair of powered, heated, memory, ventilated comfort seats in sand beige i'll sell you for $500.... that'll take care of many more techs and scratches in the future.
^^I've got a better solution - I suggest OP wrap his seats in thick plastic like my 90 year old Italian relatives do with their sofa and lamp shades.
Personally, I don’t like it when the AC guy comes to my house, fixes the AC, but shatters two windows doing it - do you?
Conditioners will not fix a scrape, in fact conditioners won't do anything on modern leather seats except sit on top of the finish. Because modern leather seats are painted, not dyed. The only way to fix that scrape would be to repaint it. If done well it will be invisible (I have done my seatback outer bolster), but be aware that the repainted finish (no matter who does it or what company the paint comes from) is more vulnerable to solvents than the original finish. Any product containing alcohol will dissolve the paint. So once you have a "redye" you need to be sure you or any shop you take it to, nobody uses anything other than water and a very mild soap. This is why those leather refinisher guys get most of their work at dealerships, prepping cars for resale. Personally I think if you can DIY it's so economical it makes sense to deal with the downside. I wouldn't pay a couple hundred bucks for someone to do it though. I once did just that, and the job the dealer-recommended "pro" did was not as good as what I DIYed. It's just not that much rocket science.
Can’t be a serious statement. When you take your car to a professional for service, you expect to have it returned to you in at least as good condition as when you initially dropped it off.
That's if to say the mechanic shattered the windows in the car and was like oops.
If you've ever undone a single bolt on any car you'll have realized you step in and out of the car several times - sometimes with tools, or things in your pocket or a myriad of factors. Small to decent chance maybe you nick something in the process - it happens.
What's at stake here is that PO contact the shop about it to see if there's a resolution. And if not - there are a ton of products that can help mitigate the "severity" of this scratch. And if not - I don't know... car must be a write off. Launch it off a cliff. Consider seppoku. The world is over.
^^OP's title in 1st post says "My New Indy". If I had a new Indy doing work on my car, if there were any issues with slight damage or scratches, I would be quick to bring it up and resolve it.
If a new Indy plans on return business, they would certainly step up to the plate and remedy IF they were responsible honest people.
If the "scratch" on OP's seat was not photographed as a close up, and the photo taken from stand up position a normal eyesight distance way, I believe the scratch would be hard to see OR extremely minute compared to the extreme closeup image above. It's easy to make things look worse with proper lighting/etc.
I'm as **** as the next guy and probably worse, but personally, I don't think I would have even noticed this scratch on a pair of normal non-sport seats with perforated leather....And if I did notice this, I would simply buff it out with a cloth and leather care product making it look better and not ruminate over it.
And as far as giving OP crap, it is all in good fun - Nothing personal. We all get bent out of shape at times and understandable.
I would have brought it to the attention of the indy right away. Not much they could do about it but at least its got to be good for an oil change or two.
Well regardless of where you stand on these things, one thing is for sure - the longer you dilly dally over it, the less likely the indy will make it right. When these things happen, you need to go back right away. If not, then there is the suspicion that someone else did the damage. These shops get claims of damage all the time, some legit, some not. Don't be afraid to address it either. Even the best shops make mistakes sometimes. Just be professional, matter of fact, and don't be one of those freak-out people, and you'll get a good result. Wait a week, and you'll get a justifiably suspicious look.
