PSE Tip and disable connector
connector behind air-box
orange plug
two questions please:
1) tried to find an orange colored connector in the engine bay but only thing that resembles this is behind my airbox....is this the connector (circled in RED) I un-plug to disable the vacuum solenoid so my PSE is on full-time?
2) I took out the 13mm bolt holding the exhaust tips, but they won't pull/come out. is there another hidden screw/clamp I need to loosen? trying to take some measurements to see if a 991.1 dual exhaust tip works here. thank you
Yes that is the solenoid for the PSE - All you do is remove the vacuum line and plug the end of the line as well as connection into solenoid.
My PSE was disconnected by previous owner and there is a special small plug you can buy to cover vacuum line as shown in photo marked with red arrow
Others have said to just unplug the electrical connector instead of vacuum tube. Either way works I assume, correct? Any advantage to either method? Thanks. I need to do same thing because I like the sound better with PSE activated but having sport chrono on with it is very annoying with the throttle changes with daily driving.
Just unplug the connector. Then you won't wear out the vacuum solenoid while you're not using it. Looking at dyno graphs, we've recently established that the car actually makes a little more low end torque with PSE functioning the way Porsche designed it. Closed at low RPMs and open at high RPMs, but it may not be enough to matter.
That one bolt is all - loosen, wiggle, and pull.
