Question on Sport Plus Mode
I test drove a 2011 911 C2 with PDK and Sport Chrono. The shop's owner told me that driving in sport plus mode required manual gear shifts. If sport plus was enabled in auto, the car would shift at red line as an override to prevent over-revving.
This is counter to my understanding, which is that the sport plus mode changes the shift points towards higher RPMs, with the primary benefit being in automatic mode. Am I mistaken? I looked in the operator's manual and didn't see a clear statement regarding the use of sport plus mode under manual or automatic shifting.
Am I wrong?
Am I wrong?
Auto/Sport will shift at higher RPM. Auto/Sport Plus it will not shift until redline. I'm guessing the reason for the shop's comment is that it's not really practical to drive in Auto/Sport Plus unless on the track. Manual/Sport Plus will allow you to decide when to shift.
Am I wrong?
Am I wrong?
Thanks. Are there advantages of using sport plus w/ manual shifts beyond the stiffer shocks and changes to PSM? I've read posts claiming that people primarily use their car with sport plus enabled, but I guess that doesn't necessarily mean that it's a good idea.
In Spot Plus the suspension will be the same as Sport and PSM less intrusive. The advantage is that you can shift manually when you want without the computer interfering and have slightly quicker shifts than in Sport/manual, giving a little more of a manual transmission feel, though not really IMO.
If you're an auto guy, you'll be fine. If you're a manual guy, buy a manual.
Sport Plus in manual mode has quicker/firmer shifts and PSM limits are higher. It can be fun on a good canyon road.
I guess my question is whether sport plus mode is only intended when shifting manually.
I’ve had a manual for a while, but the PDK shifting is pretty impressive and certainly far better (not just faster) than I am.
Can you clarify why sport plus should really only be used with auto when on the track, but is fine when manual shifting otherwise?
I do often use Sport Plus in M mode on the open road, especially on canyon-type backroads.
