Coilover Choice for 997.2
Been looking to change out my stock suspension for coilovers (not a fan of replacing just the springs). My plan is to run about 4-5 HPDEs per year (for this year. It might increase if I can find more time). I’m not too concerned about cost, if they are the right choice. However, $10k for Penske is not a choice I would make. $6k is my limit I guess. I have PASM, but I’m not too concerned about losing it for the proper setup. From what I’ve read PASM doesn’t work quick enough for the track. Here is the list I came up with.
Olins Road & Track
JRZ RS Pro Sport
JRZ RS Pro 3
KW Clubsport 3-way
KW Clubsport 2-way
With only 4-5 track times per year, is 3-way overkill? I’ve got to think long term. Don’t want to buy again.
Thanks for any input.
Matt
Olins Road & Track
JRZ RS Pro Sport
JRZ RS Pro 3
KW Clubsport 3-way
KW Clubsport 2-way
Matt
lostdog (01-24-2021)
Not sure what problem you are trying to solve especially for 4-5 DEs/year. MCS makes excellent product but you have to look at suspension as a system approach... sway bars, tire setup, alignment, bushings, spring rates,.. driver's input and experience. You open up entire new setup where everything works as a system. I would talk to your shop first.
I run the ohlins r&t and am happy with it. But based on your options now, I’d go with the mcs one in the classifieds as my first choice. The jrz rs pro would be my second choice. Lot more adjustability which comes at a higher cost but worth every penny in my opinion.
I just picked up an 06 C2S and am in a similar position. I used to Instruct for PCA about 10 years ago, had kids, dropped the fun car and am now just getting back into it. Hoping to start with 4-5 days this year and build back up. How much experience do you have with suspension tuning? Is there a local shop that is familiar with one of those brands? It’s a lot to invest on shocks if you don’t have the support for them and it could actually make you slower.
Im taking a different approach and building a solid foundation first. I am collecting a ton of parts for spring time including RSS Front LCA’s, solid rear upper dog bones, rear toe adjusters with lock out plates, front and rear gt3/gt2 sway bars with drop links, H&R springs for now for altitude adjustment, and then upgrading to slotted rotors and a proper pad with gt3 fender liners and cooling ducts throughout. This is going to allow me to get a proper track alignment and get good camber out of the front and rear, stiffen up and minimize suspension movement due to rubber. Not going to have any unsettled rear movement under braking, and the car will have proper braking and cooling as well. From there I’ll then work with a shop as I progress back into the game and determine what the proper full 2/3 way setup should be.
everything I mentioned above can be done for under 6k and I feel would be a much better approach then jumping straight into a complicated Coilovers system.
Don't give up your PASM, buy coilovers that are compatible with TPCs DSC box and then utilize PASM the way Porsche should've, as a fully active and dynamic suspension system based on g-forces and other parameters.
There are 2 choices for you - Bilstein Damptronics (what I have) or TPC's Tractive DDA coilovers. You can make the Bilsteins react in larger jumps (faster) by how you program the parameters in the DSC box.
Wish you were closer as of take you for a ride and blow your mind. I installed a nose lift kit at the same time, which is the black airbag section you see at the top of the coilover, underneath the Tarret Monoball top mount, along with an RSS Stage 2 kit.
Matt,
I too would recommend the DDA Tractive setup from TPC. Since you have the PASM in the car now adding the control box and their coil-overs will give the best of both worlds with cutting edge suspension technology. If you want to adjust the ride height you need new springs or a coil-over setup. The PASM system lets you use a softer spring to give you better road manners and the speed of the Tractive dampeners mades the softer spring rate act stiffer on the track. I run the stock Sport PASM setup with the TPC roll bars and the DSC controller and the car is fantastic on the track. This summer I hope to add the coil overs.
Lots of flavors out there and from your list you will not go wrong with those set ups, I just think the PASM setup is a great start and building off that tech makes the most sense.
Don’t some of these coilovers have significantly accelerated service schedules compared to other options?
Per Presto... “As per the manual the ohlins do have to be serviced every 30,000 kms (18,650 miles) of road use or 10-20 hrs of track time. Service includes changing the oil, seals etc.” - https://rennlist.com/forums/997-foru...s-r-and-t.html
In 2010, enter DSC, a device that can actively controls the damping force and its user programmable. DSC took these dampers and OE PASM dampers to a new level of performance. They are still not in the same class as Tractive ,as IMO they were never intended to be, but a good performance-to-dollar value at internet warehouse price. Another words, Damptronics + stiffer springs + DSC can match the damping performance of a GT3 with DSC, minus the rest of the car.
Thanks for that perspective, Tom. I don’t recall any of the reviews made of damptronics being paired with DSC. looks like I may need to do some more research.
Matt
