My 997.2 C2S with Ohlins R&T
My 997.2 C2S with Ohlins : Now painted Meissen Blue
Finally got the Ohlins road & track coilovers installed in my 997.2 C2S. The car had the PASM suspension and the shocks were due for replacement soon due to wear and tear.
Considered the Blistein PSS which are PASM compatible but then figured i would also have to get the TPC racing controller to get the best benefit. Had the KW v3 in my previous car, they were good but wanted to try something new and decided to give the ohlins a shot as they are priced well. I wanted to weigh the oem vs ohlins but forgot, i do remember them to be considerably lighter.
Right now the ohlins are setup at 15 clicks front and rear (approx 34 clicks total adjustment). Damping adjustment can be done with car on the ground, just turn front wheels to one side and the valve is located at the bottom of the strut. For the rears, it is adjusted from the back seat above the shock mount. I have ordered some extenders so that i can adjust them without removing the bose subwoofer and accessing the shock mount. Once the extenders are installed rear damping adjustment will be easy.
Current Alignment numbers are -1 degrees camber up front and around -1.4 rear. Toe in (997.2 oem spec). Cannot seem to get any more camber up front, i would have preferred -1.8 degrees up front ideally. All OEM control arms and toe adjustment. I did replace the front and rear strut/shock mount and the front strut bearings with new OEM parts.
I settled for a mild lowering as the car is daily driven. Also note any further lowering of the rear will definitely require rear adjustable toe links at the very minimum.
PASM must be disabled when going with a non damptronic suspension setup which can be done with PIWIS or a durametric pro. This is still pending and I will have to get it sorted this week. Right now driving with PASM error. It will also prevent sport and sport plus modes from working till the PASM delete coding is done.
Still considering if i should buy spacers, i have the wider wheels (8.5j and 11.5j setup) so anything more than 5-8mm might be too aggressive for my tastes
There is a significant difference in handling. Turn in is much better, almost all the understeer is gone and car is more neutral and very predictable when the rear end starts to go. Ride is quite compliant and does not bang and thud over bumps on the road like it did with the PASM. As per the manual the ohlins do have to be serviced every 30,000 kms (18,650 miles) of road use or 10-20 hrs of track time. Service includes changing the oil, seals etc.
I have ordered RSS semi solid engine mounts to tighten up the handling some more. Will update the thread once its installed.
Mandatory pic
Mandatory pic
Beautiful and clean looking 997. Looks amazing. I’ve been looking for this setup myself with Öhlins R&T
I was looking for Eibach springs only at first but thought it might be better with the adjustable height. Also more flexibility for track days etc
The only hesitation I have is ride quality on bad city roads. Is it like with PASM activated or somewhere between PASM and std? Or maybe even more stuff than PASM?
Thanks for the post Presto.
Racetwin2, me too, I know Ohlins has a great reputation in the motorcycle community.
I didn't know about the prescribed 30 hours between maintenance rule, however. Presto, any idea what that servicing cost is and how long the car would be 'down' for?
Thanks again,
Colin
Thanks again,
Colin
Beautiful and clean looking 997. Looks amazing. I €™ve been looking for this setup myself with Öhlins R&T
For USA costs better contact ohlins usa directly https://www.ohlinsusa.com/ohlins-usa-service
from the owners manual, recommended service schedule. It is the recommended, i have seen others use it for much longer than the recommended schedule.
This is the damping suggestions based on what type of driving you will be doing.
47k miles, rear shocks had a very small leak. Also while driving a bit hard you could feel the shocks were not doing a good job with the damping. I have a feeling the previous owner liked to fly over speed humps.
I also inspected all the bushes and the drop links for any wear or cracks and they all look to be in good shape. You might want to inspect the bushes, cheaper solution than replacing the suspension.
I've had top of the line Ohlins (with extra oil reservoir and both rebound and compression adjustment) on my Audi and they were AMAZING, probably the best coilovers money can buy... BUT, it was an absolute nightmare to setup 100% correctly, and I could never dial it in perfectly... I think I wasn't experienced enough to be able to change the rebound and compression settings for best street or track setup. I kinda went with what my supplier suggested and it was OK, but not perfect... so I decided to get rid of them as I wasn't fully utilizing their capability and it was kind of a waste.
I think generally OEM Porsche suspension is dialed in BEST for street/track combo duties, and I've NEVER come across a better combo setup... they're either too soft, too hard, too bumpy, etc... TPC chip is probably the best option for street/track. I think a suspension like Ohlins would be great if you primarily track and can dial it in perfectly.
I went for the ohlins road and track(R&T) as its the best compromise for a daily driven car with some track/spirited mountain runs. R&T is single adjustable which means turning the adjusters adjusts both rebound and compression at the sametime. Easier for setting up.
I agree the double/triple adjustable ones are a lot harder to setup and its more for cars that see a lot of track use. I disagree with you on the OEM C2S suspension being the best for street/track use though :-)
got the RSS semi solid mounts installed today. Did not get a chance to puta lot of seat time after install.
My old mounts do seemed to be shot as they hang a bit low (rubber part under the mount)
Initial observations, idle seems to be a lot more smooth, very minor extra vibration. Nothing annoying.
Took a couple of corners quick and there seems to be an extra firmness in the rear end. Will put some more miles on it and update
Old mounts
I had had also changed the front brake pads few weeks ago. Installed the hawk ceramics as amazon had them for $120 shipped which is the lowest I have seen. Got new brake pad dampers as well but reused the rest of the hardware.
dusting is definitely less than the oem, bite and feel is similar. Next up rbf660 brake fluid and gt3 cooling ducts.
Old mounts
