Trunk and Engine Latch Issue
Old Feb 4, 2019 | 12:44 AM
campbesl's Avatar
campbesl
I have a used but perfectly good switch set. PM me if you want it.
Old Feb 4, 2019 | 09:57 AM
Astur's Avatar
Astur
Originally Posted by jmcg0v
I was able to get to the wire using some paint sticks to slightly spread the opening between the bottom of the tail light and the bumper. Then using a flashlight, I was barely able to see the wire and then pull it out using a coat hanger.
I strongly suggest that you look at my above post (#6) for a more permanent and less invasive alternative to yours.
Old Feb 4, 2019 | 10:12 AM
Petza914's Avatar
Petza914
Originally Posted by Petza914
Isn't there a motor back there too. Seems like there's a pop and then you can hear something running. I'll try one and see.
I tested this for you this morning and after the pop sound of the release, there's definitely a whirring sound from a motor doing something. If you don't get the motor sound, that might be your issue.
Old Feb 4, 2019 | 03:28 PM
jmcg0v's Avatar
jmcg0v
2nd Gear
removed post
