991C2S cabrio - soften the ride?
I've got a 2011 911 C2S convertible I bought last year. It's at just over 60k miles now, all running good. It has PDK and sport plus/chrono with the PASM. Stock wheels, stock tire sizes (Pilot Sports).
I'm having lower back issues and wouldn't mind making the ride a little more compliant. Oddly enough, the base seats, despite being hard as rocks and lacking adjustments, have a lot of support and good angles for me. If I could get the ride a little more supple, I'd be pretty happy.
Not sure what, if anything might help. Most of the aftermarket parts are designed to make things more rigid and sporty, not supple and compliant.
Was wondering about the PASM shocks. They're not showing a lack of damping, but at 60k, don't know how much wear might have affected them. I'd also imagine they're outrageously expensive. Or tires, perhaps wheel sizes. I can't say the existing tires are bad at all.
May consider selling the car, but I like it. Cars can be super hard on my lower back. The seats in the Porsche are good for me, some cars are just brutal though. I had an SL400 before and those are good seats for me too. My wife's BMW is just murder though.
Thoughts?
Thoughts?
Here is the thread:"https://rennlist.com/forums/997-forum/888730-dsc-sport-tuning-software-discussion-thread.html".
The company is DSC. Let us know of your experience if you decide to go that way.
Good find!
I looked it up, $1200 for the module. Installation is a literally snap-in. I'll enquire with the manufacturer if it will do what I'm looking for.
Tell them what’s going on and they can make normal ride mode even softer for you right out of the box.
Kurt
The DSC will soften the ride to softest you can go with your springs. I have the module, takes 5 mnts to install, no tools.... stupid easy. If you don't like it, 5 mnts to remove and then resell on Rennlist.
Read my review here: https://rennlist.com/forums/997-foru...y-opinion.html
I personally find their softest setting a bit too soft.... the controller controls the shocks not the springs. DSC loweres the adjustment value to its lowest setting at slow speeds and low g force among other inputs. Given the S has pretty stiff springs, the car can bounce or get floaty over humps in the road. Some don't see this as a problem, I do. So I keep it in sport mode... even this is softer than stock.
I highly recommend this product.
Otherwise, you will need to buy springs.... changing shocks won;t work as the DSC puts the Porsche shocks into their least setting and this is softer than I think any shock should be given the stiff springs.
You could move to 18" wheels..... this is a standard Porsche wheel size and the side wall of the tire gets higher (circumference of the total wheel/tire does not change). This will soften the ride a slight bit. I have 19" for the summer and 18" for the winter and tell the difference. However I doubt the wheel change will get you where you need to be with your back. The DSC is the ticket.... and a lower cost low risk alternative to new wheels and tires.
BTW: I keep bending these 19" wheels.... I suspect I will buy 18" wheels and tires for summer when these tires where out... I've been threatening to do this forever.
Peace
Bruce in Philly
Peace
Bruce in Philly
