Door Removal
There are about 10 billion posts and YouTube videos on removing door panels but I feel like I'm going insane trying to find a tutorial or vid for how to remove a door.
Any help pointing me in the right direction or a quick overview of the steps would be immeasurably appreciated!
The forum DIY: https://rennlist.com/forums/997-foru...l-removal.html
To remove the door you have to
- Remove the electrical harness from the door or from the body. If you aren't taking the door apart, just remove the harness connector on the inside of the car and then feed it through the holes in the frame.
- Take the bolts out of the bottom of the hinges.
- Unbolt the retaining lever from the door frame.
The door then just lifts off the hinges. Be careful.
