QSC exhaust tips installed
https://www.ecstuning.com/b-racing-d...970800372~rdy/
These the ones you got? They look great, and i'll probably pull the trigger myself, I like that they're 90mm and larger than the OEM 997.1 S tips.
Just weird though bc it says in the description, excludes 4 tip 911S. And i'm assuming your car is an S, per your badging.
I just bought these for my Carrera base 997.1 lost one of the OEM tips one night driving home. Came with 3 sleeves that seem to be useless. If I push them as far back as possible on the pipe I still dont have enough adjustment to tighten them into place. Any advice since i think you also had the base tip and replaced them with these? Thanks in advance.
