Brake issue on my '11 GTS
That's a very astute question as the PSM will use the rear brakes a lot to tame the weight at the rear of the car, so even if you don't think you're using the brakes, the car might be and that could add a lot of extra heat into the fluid.
I agree "PSM on" will/may use more of the braking system, but the only variables between this session and others were the new pads, and the braking fluid change.
Brake cooling will help. I was boiling in my GTS in the last session or two of a 7 session day before going to GT3 fender liners and GT2 ducting. No fade all day now.
PSM being on will totally kill your fluid. Definitely turn it off and just take it a bit easier until tire temps are good and you're comfortable with how the car feels. It will kick in anyway if things get really out of hand.
great to hear more people tracking these cars. don't give up, you'll figure it out. this problem isn't too complicated but there are quite a few variables.
Interesting enough looking at your signature, my previous ride was an '06 E46 M3, and now '11 997.2 GTS.
Be sure of it, I do not give up tracking my car. Clarification on PSM needed: I was under the impression that if left off, you were on your own.
In the Mustang, from D group (lowest) to B group (second highest) in our club ARPCA (sessions of two days each, 4 runs per day), for many years and 2X per season, plus intermediate and advanced at other sponsored and track conducted events, at Watkins Glen and Pitt Race, over 4 seasons, with very hard driving as I got better. With the 911, two Club sessions, B group, at Watkins Glen and Pitt Race, and one session, one day, 5 runs, advanced group (highest group for that event). Running as hard as I can, and against a lot of guys who trailer in vs. drive in like me with street gear (although I do have track wheels - the C4's with MSS on them on the 911). I always use fresh fluid, Motul 600 is the first choice. EBC YS are just as good for me as the Pagid 29's. The Pagids do grind the rotors more though. Regardless, with very aggressive driving and braking on track, I've never had fade with either system, and the Mustang brakes are generally crap - they performed just fine with Motul and EBC YS.
Is it possible that you are missing a heat shield between the pads and calipers? (I'm relatively new to this, but in other discussions I've read people mention small ceramic disks that are placed between the pads and pistons to prevent heat getting into the piston. I've also seen titanium heat shields that are placed between pads/pistons; again to prevent the heat from transferring from the pad to piston and boiling the fluid.)
Former Vendor
Hello,
With your stint being so short when you’re experiencing issues leads me to believe there is a different problem. Going 15mins and boiling fresh brake fluid of any kind that has a dry boiling point of 600+ F is very unlikely in this application.
If the RBF had been boiled to this degree and that quickly there would be proof of it upon visual inspection most likely- mainly vapor/air present in the lines. When air/vapor is present in the lines it is compressible, therefore you get a soft pedal. Brake fluid cannot be compressed when no air is in the lines.
If not, I would look to overheated brake pads, the condition of the ceramic pucks on the caliper, or as others have pointed out, some form of traction control being on and creating unnecessary heat -Nick
I went off track once in my S4 after the ebc yellowstuff basically melted, corner worker ran out thinking my car was on fire. Granted that was before I upgraded to a BBK, but those pads seemed pretty sketchy to me, crumbled like coffee cake after the incident. I ran carbotech after that and Ferodo on my 911. I find it hard to believe you boiled fresh RBF660 after a single 15 minute session. Not sure how air would be in your lines beforehand, but I suppose something with the ABS pump is possible if you let air get in there (using the dry bleed method with a power bleeder and forgetting to refill the reservoir.
