Significant hydroplaning, excessive tire wear, rear tail "wag"
Am I reading that right......3,915 miles on the SO-4's? That's pretty extreme. As others have said, have your toe and camber adjusted to more conservative settings. I told me dealer to set both for regular street use and I get on average 10,000 to 11,000 miles on the rears and twice that on the fronts. And my car is lowered. No reason you shouldn't be able to get the same, or even better if you're not lowered.
As for hydroplaning, the rear starts to dance around on a rain soaked road once the inner 2"-3" start going bald. Doesn't matter how good the rest of the tire looks. And I think a lot of people don't realize that you really have to get on the ground to see what's going on with the rear tires. You can be down to the cord on those inside 2" to 3" while looking at it standing next to the car you'd think you have at least 15,000 miles left on that same tire.
That's right. Extreme tire wear. It's got to be the toe (rather than camber) because the wear across the tire from outer to inner is uniform. My alignment values are in an earlier post - I didn't think a misaligned toe could wreak such havoc.
Is it possible there's a suspension part that's broken/worn that could contribute to excessive tire but not necessarily show up on a static alignment?
When researching my car's issues, I came to learn that it's best to increase tire pressure judiciously to combat hydroplaning because the proper/extra pressure reduces/resists the amount of tire deflection due to the impinging water. I had always approached it the other way - reduce the tire pressure - no longer.
...article with respect to hydroplaning: https://m.tirerack.com/tires/tiretec...e.jsp?techid=4
And I might not be a Porsche expert, but oh gods yes am I suspension and alignment. Oh yes. And it's your toe. It's absolutely your toe as the starting point. Thankfully you don't have a C4, where toe adjustment is not open season. I could go in depth on what I'd do (which is honestly going to be a LOT more than Innovative only because I am a perfectionist who won't accept anything but absolute dead-on,) but if I was going to have anyone else do it in Texas? I'd call Innovative.
Negative toe-in is the reason rear tires wear. The factory sets relatively high rear toe-in to induce understeer, and make the car safer for most drivers. Now, if you know how these cars should be driven you can cut on understeer and reduce tire wear. I routinely wore rear tires in the 10-12k mile range. Since i minimized rear toe-in (and changed to Michelin Pilot Super Sport) my rears have 22k miles and they are wearing evenly. Same rear negative camber and same driving style. In dry weather I figure the rears have another1-2k miles left. The extra wear is due both to minimal toe-in and the much longer wear Michelin tires (both Pilot Super Sport and Piot Sport 4S). All street/road driving.
And this is why I insist on checking (NOT performing, just checking) the alignment on anything high performance pretty much every oil change. Especially since a check now takes less than 30 seconds. Or worst case,
Charlie says it's the shocks - all around. The fronts have excessive bushing wear (at least) at the top of the strut. The rear struts offered not enough resistance to compression when fully extended. The rear LCAs had tears in the bushings so I'm going to replace them. No visible fluid leakage.
I'm thinking about going to Ohlin R&Ts (and coding-out PASM). I'm interested in opinions about the Ohlins. I'll probably dial-in some preload to reduce the ride height about 0.5 inch from where it is now.
After all that, an alignment to at least get rid of almost all rear toe-in...
Unfortunately, the damn AOS ruptured on the way home from work on Friday so the suspension will have to wait for a bit until I get that changed out, along with all the chain tensioners since I'll have the A/C compressor out.
Nothing wrong with ohlins but they do require rebuilds every 20k miles or so which can be a pita. When my pasm shocks go ill probably replace with bilstein b12 kit which matches awesome bilstein b8 damptronic performance plus dampers with matched eibach mild lower springs for under $1400
mike
mike
Also, be cautious of used Ohlins. They are rebuildable, but not infinitely, and not all parts are replaceable. There is no part more expensive than a used racing part.
Man... what's the saying? If it wasn't for bad luck, I wouldn't have any?
A question about the rear wishbones (aka, LCAs?) - is it important that the bushing be oriented so that the "connected" portion of the rubber be aligned with the control arm (aka, trailing arm?)?
Should they come from the factory like this? How about if it's the Meyle brand?
